Trans fluid temps - manual
It seems that under road racing conditions the manual transmission fluid (redline cocktail) is getting hot. It doesn't look particularly good and we are considering putting a pump and cooler on it but want to get some temp data first.
Does anyone currently run a transmission temp gauge now? If so, whose and how did you install the sending unit?
Any recommendations on a different transmission oil that might hold up better under heat?
Anyone have a pump and cooler installed now for their manual transmission? If so, whose and how did you do it?
Thanks.
Thanks.
Ok, an update.
Installed an AEM trans temp gauge. The sending unit was installed in the transmission drain plug. Drilled and then threaded. Wires were then just run to the dash and the gauge installed by the AC controls. It doesn't matter as there's no need to constantly monitor. just keep an eye on the temps.
On the Dyno for a while and the temps get to about 175, which is about right. We'll see if they get much higher at the track.
Thanks
boomn29
Jul 8, 2019 05:09 PM
