New pickup: GTX3071R
Old Aug 19, 2012 | 10:25 PM
jwoodzx7r's Avatar
Showed up last week and wanted to share some pictures. GTX3071R w/ bigger inlet and outlet pipes from ATP. It will be a little bit but I'll definitely be posting my results with this snail after I have it tuned. I just gotta find the time to be able to do this and my Exedy Twin install, being my DD finding a few days downtime is difficult lol. Thanks to ATP for the help and MAP for the deal!
Anyways, enjoy... (not sure why upside down but oh well)
Old Aug 19, 2012 | 10:28 PM
xezerax's Avatar
Sweet finally someone has this turbo, looking forward to seeing your results!
Old Aug 19, 2012 | 10:30 PM
jwoodzx7r's Avatar
Ha, my thoughts exactly. Wanted to try something different since there's not much feedback/results on this guy that I've seen on the board
Old Aug 20, 2012 | 12:23 AM
linjy2's Avatar
In for results also. Pump or e85?
I had the old gt3076r. Was a nice turbo. Just too laggy.
Was tempted to upgrade to the new gtx
Old Aug 20, 2012 | 07:59 AM
jwoodzx7r's Avatar
I'd like to get #s on both but pump will be more DD because we dont have many e85 pumps around Seattle. Not sure my injectors will even be big enough for e85, 1100s??
Old Aug 20, 2012 | 09:44 AM
Pbayr0lla321's Avatar
Are you currently on stock pump and injectors jwood?
Old Aug 20, 2012 | 09:53 AM
B.J.@ToxicFab's Avatar
Returned your PM sir!
Old Aug 20, 2012 | 10:16 AM
spdracerut's Avatar
It looks like you got the big A/R?
Old Aug 20, 2012 | 10:17 AM
spdracerut's Avatar
Which A/R?
Old Aug 20, 2012 | 10:31 AM
jwoodzx7r's Avatar
I did, its the 94. As per ATP their suggestion was doing a hybrid with the 94 as the 73 spools a little too quick and can choke up the turbo. Ofcourse the 94 will cause a hit in spool but how much, obviously we'll see how that turns out...
I'm on stock inj right now but I have a set of FIC1100 in a box that'll go one with this... stock pump. If anything I was thinking a bigger pump maybe for e85 support rather than that AND bigger inj than the 1100. I dont plan on ever going over 28lbs so I am guessing 1100+ would be overkill? I've done some reading on all the e85 posts but not as much as I could since its so infrequent in my location, so I have to apologize I dont know much about it. Would running e85 have any influence on spool?
Old Aug 23, 2012 | 04:53 PM
anasyakoub's Avatar
Nice choice
I'm planning to get GTX3076R but I don't know what inlet and outlet to choose !!
Old Aug 24, 2012 | 08:24 AM
jwoodzx7r's Avatar
I would give them a call and chat with them or via email... very helpful. I was actually planning on going the 3076 route too until I spoke with them and decided to go w/ the 71. One of the things they suggested was if you are going to go with a 3076 you might as well go with the 3582 because the loss in spool is almost none-existant (according to their testing on e85). Anyways, very good dudes... give em a ring.
Old Aug 27, 2012 | 06:40 PM
DeMoNz's Avatar
Originally Posted by anasyakoub
Nice choice
you should go with the 4" outlet...the stock 2.5" is too restrictive. however you will need a new intake charge pipe
Old Aug 27, 2012 | 11:52 PM
palmerblock's Avatar
ive down graded from a ATP GT35r to the ATP GTX3076 4in, 2.5 out... not really a downgrade kinda like a bas ackwards upgrade.... none the less, good choice to the thread starter.... looking forward to your results... ill post mine also as i have alot of testing im going to do...
Old Aug 28, 2012 | 06:31 AM
anasyakoub's Avatar
Waiting Your results
