Overboost Puzzle
Old Oct 16, 2012 | 04:47 PM
  #31
toodrunk2see's Avatar
Originally Posted by richardjh
The phrase "WARNING - DANGER TO MANIFOLD!" was doubtless running through their heads.
Rich
ROFL well played sir
Old Oct 16, 2012 | 07:01 PM
  #32
momostallion's Avatar
yikes. i guess someone either got tired of the o2 dump or decided to silence it for trade in purporses
Old Oct 16, 2012 | 07:12 PM
  #33
REVOlution X's Avatar
I wish I knew who did it. They clearly dont need to be in business. Im just glad we found the issue. Im still in shock and awe over it and never would have thought that it was the problem. Good thing we put it on the lift and inspected the DP.
Im still running the Forge WGA with the Red spring and its spiking to 28lbs and holding around 20lbs to redline. Virtual Dyno shows 381hp/334tq on a 4th gear pull. I pray that no one else ever has this issue.
Here's the pics from today.
Before:
After:
Old Oct 16, 2012 | 07:15 PM
  #34
I agree. Mitsu told me that the guy who traded it in "switched it all back to stock."
Old Oct 16, 2012 | 07:45 PM
  #35
Wow so you bought this from a dealership? As soon as you found that I would of taken it to them and made them fix it or at least pay for whatever it cost you to get it fixed.
Old Oct 16, 2012 | 07:57 PM
  #36
at least that is resolved. personally i'd pull the 28psi down a notch or two. maybe check spark plugs and compression test the motor while you are at it.
used cars are typically as is.
Old Oct 16, 2012 | 08:59 PM
  #37
Yeah. I have to order the plugs. Went to a couple places today and they didn't have any NGKs in stock. I turned the Hallman down two more turns after the last log. Shouldn't spike past 26 but I'll know for sure when I can do some more logging. Boost gauge showed a peak of 26.8 on the last run I did coming home.
As for a compression test, I may look into that too.
simons3z
13
Feb 3, 2017 03:52 PM
ghad
May 25, 2014 02:27 AM
CDrinkH2O
47
Oct 17, 2012 08:13 PM
awdordie
18
May 6, 2012 07:48 AM
rudy91889
Jun 4, 2009 02:52 PM
