Leaking transfer case fluid, going to dealership
Old Sep 2, 2012 | 02:58 AM
nessus's Avatar
Briefly searched on google, it seems this is a quite common issue for alot evo x owners which I didn't expect. I am driving a 2010 model Evo X GSR.
Noticed it about 2~ months ago, took it to the dealership, it wasn't serious at the time, merely some damps. So they refused to do anything other than cleaned it up for me. Now for the past a week or so I could smell burning oils every time I drove my evo for more than 30min. I knew the leak got worse. I could trace the fluids all the way back to the muffler.
So I called the dealership today and scheduled to take it in after labor day next week. Hopefully this time they will fix it for me while it is still under warranty.
I will keep you guys posted.
Old Sep 2, 2012 | 12:24 PM
scheides's Avatar
EvoM Moderator
Find the thread about how a bunch of cars had their xfer cases over-filled from the factory. Check the fluid level.
Old Sep 2, 2012 | 02:06 PM
nessus's Avatar
Thanks. Searched more using your information on the forum. Now that I believe its cause by either an overfill (I did flush my transfer case fluid a few weeks ago along with other fluid flushes) or a seal leak. Although I am still believing towards its a seal leak. I think the leak is from between the transfer case and the drive shaft.
Some threads mentioned the owners had to have their transfer case replaced to fix this either an overfill or a seal leak between the xfer case and the tranny? I really hope I don't have to do this. Better double making sure everything is still under warranty when I drop my car off at the dealership next week. I have an aftermarket air intake, a short shifter and a custom tune. Maybe its safer to reset it back to factory just in case. For the last couple of visits to dealers I didn't bother to do it.
Old Sep 2, 2012 | 02:18 PM
XTR Performance's Avatar
I would 100% reset the ECU back to it's stock settings when you bring it in. Just in case they decide to check and you really have a serious issue .
-Chris
Old Sep 5, 2012 | 09:12 AM
nessus's Avatar
Thanks guys. Got the car back from dealership last night, it was as I expected the seal that was leaking between transfer case and rear drive shaft. According to the technician, it was re-sealed. He had to take off the rear drive shaft to do the job. But it was all done within half a day. 0 charge, all under warranty.
I will for sure lift it up on the weekend to verify everything myself again. Trust no one, right
Old Sep 5, 2012 | 11:08 AM
Kracka's Avatar
https://www.evolutionm.net/forums/ev...ase-fluid.html
Old Sep 5, 2012 | 02:03 PM
nessus's Avatar
Forgot to ask the other question. The invoice/report sheet I got back from the dealership mentioned that transfer case oil was topped once it was re-sealed, which makes sense since it must have leaked more oil during the re-seal process. But my question is that I flushed the transfer case oil at friend's shop a few weeks ago with non-stock fluids (AMSOIL to be exact). So right now my transfer case is probably running mixed brand oils in it. Should I be concerned about this?
I mean its not too big of a deal, I could always order another bottle and flush it again. But you think it's necessary?
Old Sep 5, 2012 | 03:57 PM
Johnr352's Avatar
yes, flush it and replace. Some oils don't mix well.
Old Sep 5, 2012 | 06:18 PM
Kracka's Avatar
Should be fine...should
Old Sep 8, 2012 | 09:33 AM
ChicagoEvo9's Avatar
bump
Old Sep 8, 2012 | 05:24 PM
Rat Fink's Avatar
My X was at the dealer for over a month this summer getting a new transfer case. the seal Popped but It was done under warranty.
Old Sep 9, 2012 | 11:08 AM
nessus's Avatar
Lifted the car on Saturday to make sure. Yes, things look alright. Leak stopped, and dealer cleaned up at the leaks too. Pretty good job. I guess I will give them a positive feedback
Old Sep 9, 2012 | 04:07 PM
genelee112601's Avatar
Good everything was covered and done
Just done my diff , tranny flush today so far no leaks
Old Sep 9, 2012 | 06:59 PM
airgazem's Avatar
You are fine no need to reflush put a few thousand on then reflush.
JIMMY_HIPPO
Jul 13, 2015 07:02 PM
DjRags604
Mitsubishi TC-SST Discussion
34
Aug 16, 2012 04:49 AM
Travis959
Southeast Region
May 17, 2012 04:12 PM
211Ratsbud
19
Aug 16, 2011 08:52 PM
kmart888
13
Jan 17, 2011 09:18 PM
