Non ball bearing turbo recommendations PLEASE!!!!
GTX3071R Dyno sheet on 2011 MR
It pulls really hard once it begins to motivate, in fact at about 3K to max boost it ramps up extemely fast. I have custom ground Tomei cams and a Kaizen exhaust header...Once we solve the fuel pressure issue It should be a flat curve to redline...or very close to it...
Anybody see the new Mitsubishi turbo upgrade at SEMA? It's part number is TF06-07 18KX3RC-12T.
Specs are:
55.10 mm Compressor Wheel Inducer Diameter
75.00 mm Compressor Wheel Exducer Diameter
61.50 mm Turbine Wheel Inducer Diameter
54.00 mm Turbine Wheel Exducer Diameter
Specs are:
Press release:
http://www.semashow.com/press/2012/0...de-turocharger
Press release:
The OE upgrade turbo would be equivilant to the FP Green if I'm not mistaken. Not really what the OP was looking for I thought? + that OE upgrade is probably going to cost an arm and a leg since it's from Mitsubishi. I would honestly go with the EF3 or the EF2w/ cams. I have a few friends up here with the EF3 & EF2 and they are absolutely great performing turbos & they are a great bang for your buck.
can't wait
