Help choosing cams
Old Oct 6, 2012 | 10:54 AM
teameditevo08's Avatar
Help choosing cams
So im mainly looking for safety not high numbers really trying to prevent blowing this motor. It currently has the kelford stage 2 cams (214b) i dont have any stock cams to use so im in the process of building the head, have to replace all the valves and im thinking of going with new stock valves unless anyone suggest otherwise. Income is not great at the moment so im looking to get the car on the road for now I will work on making power in the future that being said only upgrades on the car besides the cams are intercooler piping,750cc injectors, and a fp red but i also have a stock turbo to run if its suggested that its a better idea. So im debating if i should try to get my hands on some stock cams and not run the kelfords since they are meant for larger turbos or would i be safe running the kelfords. Any input would be appreciated im stumped just seeing what evom has to say thanks everyone.
Old Oct 6, 2012 | 12:23 PM
toodrunk2see's Avatar
If you are not running upgrade spring I would stay on stock cams. I know there are several aftermarket cams you can run stock springs with but imo if you upgrade cams you should do the whole vavletrain at the same time or at least springs and retainers. Better safe then sorry.
Old Oct 6, 2012 | 12:48 PM
yes i agree i believe it already has the upgraded springs but if it doesnt and i keep the cams in i will be getting the corresponding springs and retainers as for the valves im still unsure whether to got stock because ive heard they are pretty strong or aftermarket either way i wil getting all new valves because all my current intake ones are bent
Old Oct 6, 2012 | 01:20 PM
If are changing the valves I would just do the springs also. Stock cams are going to cost you about the same as upgraded springs.
Old Oct 6, 2012 | 01:45 PM
yea thats my plan but im worried on the reliability of the motor with the kelfords since i will be running a stock housing turbo
Old Oct 6, 2012 | 02:24 PM
I dont see why there would be any reliability issue if you put in upgraded springs with a proper tune. I would stick with the fp red also again should be fine with a good tune.
Old Oct 6, 2012 | 07:36 PM
ok thanks for the input great help i appreciate it
OG
63
Feb 6, 2014 10:44 PM
EVO'D8
16
Mar 25, 2013 11:52 AM
spadednick88
26
Dec 20, 2012 12:29 PM
snowmastergt
12
Nov 30, 2012 02:03 PM
