Anyone have their valves "adjusted"
Old Oct 21, 2012 | 07:01 PM
AWDTerror's Avatar
In the maintenance manual it says to have this done at 60k. Guessing to adjust the bucket shims. Anyone have this done? I have some ticking at startup.
Old Oct 21, 2012 | 07:29 PM
Moore Auto's Avatar
There is no actual adjustment for valve clearance, and there are no actual shims for the buckets. If you check clearances and find one out of spec you would need to order another bucket with the correct thickness to take up the slack. I haven't heard of a stock Evo needing this though. You might just be hearing injector tick.
~Chris@MooreAutomotive
Tuner/Master Technician
Old Oct 22, 2012 | 02:17 PM
AWDTerror's Avatar
Thanks!
So what does the maintenance manual speak of then?
Old Oct 23, 2012 | 05:27 AM
Dave W.'s Avatar
Originally Posted by AWDTerror
Thanks!
"If you check clearances and find one out of spec you would need to order another bucket with the correct thickness to take up the slack."
jakgal04
Apr 17, 2017 03:00 PM
EvoKnievo
Dec 30, 2016 02:35 PM
Rob_GPT
Sep 6, 2016 04:39 PM
R0ME0
May 28, 2008 01:10 PM
EvoTech
Dec 18, 2007 06:29 PM
