Loud "tac tac" sound from the valve area.
Old Nov 11, 2012 | 11:56 AM
  #31
emperor496's Avatar
what's left..
Old Nov 17, 2012 | 12:12 PM
  #32
mturn0687's Avatar
Sorry to see man.
Time for a built engine? (lemons into lemon aid)
Old Nov 18, 2012 | 10:58 AM
  #33
emperor496's Avatar
yes.. time for engine re-built.. I have change all connrod bearing, the loud knocking sound is gone.. the engine sounds normal when idle. But, if I ram to above 2500 rpm.. the slow soft rattling sound came.. so.. new connrod & crankshaft..
Old Nov 20, 2012 | 04:41 PM
  #34
Thatotherguy's Avatar
How many miles u have on your car? Do you push it hard? Is it stock or modded? How many hp ?
Old Nov 21, 2012 | 05:32 AM
  #35
emperor496's Avatar
55k, normal driving, sometimes I push it, but not very hard.. stock, (only greddy exhaust, HKS intake & BOV)
Old Nov 21, 2012 | 06:13 AM
  #36
emperor496's Avatar
I am in a process of rebuilding my engine, thinking of installing this http://www.erlperformance.com/erl-4b11-25l-stroker-kit ..
has anyone try this? need some info on this.. pro & con.. I'll be using only the stock piston size..
Old Nov 21, 2012 | 07:05 AM
  #37
Spazpilot's Avatar
I believe ERL is also the builder for the AMS blocks/ crate engines. Heard they are pretty good to work with. They'll be the ones I'll be looking at. Personally will go with a 2.4L with an FP Red when I finally decide. Sorry to here about your issues. Hope everything works out for you.
Old Nov 21, 2012 | 04:07 PM
  #38
MACKLIN's Avatar
Originally Posted by emperor496
little update on my problem.. just to share, maybe could help others..
I have open again the valve cover, we found that the timing chain "jumped" 1 teeth of the gear, so the piston knocking on the valve. job will continue tomorrow, the reset the timing chain & re-tension it. That is the only finding now. Hopefully it is only the problem.. How can the timing chain "jumped"?? that is my question to all gurus out there.. under tension?
And removing the crank pulley without air impact gun is pain is the a**, I have read people wrote, it is almost impossible to do, they're right it is almost impossible, almost.. but it is possible..
Removing the crank pulley without a air gun is easy. Just need the right tools
Old Nov 21, 2012 | 04:09 PM
  #39
MACKLIN's Avatar
You should call up mitsubishi and see if they can do anything for you.
Old Nov 22, 2012 | 10:10 AM
  #40
alex the great's Avatar
So after changing those parts do you still hear the "normal" not so loud tac tac that some people say is the injectors ?
Old Nov 23, 2012 | 03:44 AM
  #41
emperor496's Avatar
after replacing the con-rod bearing, the loud knocking sound gone.. only soft rattling sound when I ram to 2500 rpm.. the engine sound normal when idle.. loud "tac tac"/ knocking sound gone..
Fast_Freddie
102
Aug 27, 2019 04:45 PM
abrar
Feb 9, 2016 04:49 AM
Std Seven
Dec 21, 2014 09:29 PM
ehall20
Apr 7, 2014 06:28 AM
EEVOH
14
Oct 12, 2013 09:08 AM
