Fully recirculated bov
Old Dec 16, 2012 | 01:08 PM
JV21804's Avatar
I just ordered ets intake, dp, exhaust, test pipe and ic with piping. I have read that the factory bov works well. If I run a aftermarket bov 100% recirculated would it be louder than the factory bov with an intake? At what point will I need a aftermarket bov? This is my first turbo car so I am new to this and I am trying to do everything right. The car will be getting tuned right after the parts install btw.
Old Dec 16, 2012 | 02:24 PM
Kracka's Avatar
Yes.
When you upgrade the turbo.
Old Dec 16, 2012 | 02:51 PM
tehSteve's Avatar
I have the WORKS oem looking one and I gained +10/+5 by just swapping the stocker out and doing a dyno run. Drives like stock no issues bucking or anything. I had a synapse synchronic and tialqr previously and I got tired of messing around with the springs and different configurations.
Old Dec 16, 2012 | 03:40 PM
Kracka's Avatar
^Stock turbo?
Old Dec 17, 2012 | 06:44 AM
JV21804's Avatar
Steve, do you have it set to 100% recirc? Was it louder than stock? Did you need a tune? And what he said stock turbo?
Old Dec 17, 2012 | 06:52 AM
spikester603's Avatar
you will need an aftermarket BOV if you get tuned over 27psi as thats when the OEM BOV starts to leak.
Old Dec 17, 2012 | 07:32 AM
Kracka's Avatar
WORKS is a modified stock BOV, it does not have multiple settings and it will sound very similar to stock since only the spring strength differs.
Old Apr 4, 2013 | 08:20 AM
JV21804's Avatar
My main question is if I install a turbosmart bov to recirc will it be louder the the stock bov with an intake?
Old Apr 4, 2013 | 09:31 AM
kr1s's Avatar
Yes...It will. Needed...No.
Old Apr 4, 2013 | 11:27 AM
Ken-X's Avatar
I crushed my stock bov and found it performs better than the Forge Split-R and solved a shift issue I had at 6500rpm on my SST!
Old Apr 4, 2013 | 04:00 PM
zebra4's Avatar
To answer your question, yes. I have the turbosmart dual port on my ralliart. I have it set to approx. 70% recirc, and 30% atmosphere. The small amount of air released makes a very noticable difference in sound. It is literally the "pssshhh" sound when released. Also, i have 0 issues running it like this. I have tried full recirc as well, and noticed no difference, other than the sound. Driveability was the same. I am running 23 PSI on it and it holds great. Hope this helps.
Old Apr 5, 2013 | 12:08 AM
mygsx's Avatar
Somewhat it will be louder, and that is only if you listen for it. On my old Evo 8, I was running a small 3071 with a Greddy, then Synapse or whatever it is called, because the Greddy was leaking under boost. When I let off the gas the sound was distinctually louder, and sounded different than the factory metal version. I have the X now, I am pretty sure if I did the same route I would hear a different release, but it is not enough to make heads turn full boost while re-circulating, have fun.
15evotuner
Aug 22, 2015 05:40 PM
Masheen
Nov 11, 2013 05:10 PM
2012evogsr
19
Dec 8, 2012 07:05 AM
hataeeun
Jun 2, 2010 12:51 PM
HPEVOX
27
Apr 14, 2010 06:23 PM
