Hows this Clutch, Pressure Plate and Flywheel
Old Feb 17, 2013 | 08:30 AM
walls's Avatar
In July my clutch started slipping so i had it replace with and Exedy stage 1 but when i had it done i didn't have my flywheel resurfaced. A couple months later my clutch started slipping again. It got so bad that that the clutch wouldn't grab til about 4k rpm and i would pretty much have to dump it to get it to pull out. I stopped driving the car til i had time to rip it apart and look at everything. I'm pretty sure me not having the flywheel resurfaced when the clutch was changed is why it started slipping again. How do you guys think these components look?
Old Feb 17, 2013 | 12:08 PM
Gyroscope's Avatar
looks like you did a lot of 4k clutch dumps...
Old Feb 17, 2013 | 03:43 PM
Kracka's Avatar
After that much abuse and slippage, replace everything.
Old Feb 18, 2013 | 04:29 AM
evokid4life's Avatar
+1 change everything also remember use new flywheel bolts i had to learn the hard way when mine backed out not worth pulling your trans twice for $30 bolts
good luck
Old Feb 19, 2013 | 04:12 PM
jmastrol's Avatar
Lightbulb cheap OEM bolts, perhaps?
good luck
Hey evokid4life ....
Did you use Locktite when you installed the used bolts? And were they torqued to spec? Would be curious why they backed out on you because I'm getting ready to help a buddy replace a flywheel in a few weeks time. Didn't know the flywheel bolts were considered a "consumable" part.
Thanks.
-jm
Old Feb 22, 2013 | 05:02 AM
Thanks.
-jm
Yea Jim they were locktited and were torque down to spec and checked multiple times. When i asked the dealership if they were one time use only they said yes there only one time uses bolts but we now for a fact ppl reuse them
I would change them there cheap its not worth to have to pull the trans out again let alone break something.
Old Feb 27, 2013 | 11:47 AM
ACTman's Avatar
Cooked! The car rapidly becomes undriveable (clutch slippage) when the disc become too thin because the pressure plate rivets bottom out on the flywheel and the pressure plate no longer clamps onto the disc.
Old Feb 27, 2013 | 11:50 AM
Kracka's Avatar
You mean disc rivets?
Old Feb 27, 2013 | 11:59 AM
ACTman's Avatar
No, the pressure plate rivets, as in one in the top left of the fifth photo.
Old Feb 27, 2013 | 12:00 PM
Kracka's Avatar
Got it, thank you!
Golden
Evo X How Tos / Installations
100
Jun 6, 2017 09:14 AM
peteformance
Jul 30, 2014 03:02 PM
brand0n
Jul 8, 2011 06:38 AM
Jim in Tucson
West Region
May 13, 2011 09:58 PM
dwhit757
Evo X Dyno Results
May 3, 2011 09:31 AM
