Idle issue
Old Apr 8, 2013, 01:30 PM
GrandmasterCow's Avatar
Idle issue
Having issues trying to get fresh build idling. Build specs are included.
Working with my tuner, we adjusted timing, fuel, etc.. without luck. Even when setting target idle rpm to 2000, it barely stays idling above 800 and drops to 500 and stalls. Now, it only does this AFTER the engine starts warming up. Meaning, it will start and idle fine when the engine is cooled down.
Some Log files from EvoScan (The are just IDLE logs, maybe with small amount of driving)
http://s000.tinyupload.com/?file_id=95962258634900095891 (1.7MB)
http://s000.tinyupload.com/?file_id=00248903307910328136 (3.8MB)
Engine:
Sleeved 2.0
Manley TT I-Beam rods
Manley Pistons
ARP Rod bolts / Main Studs / Head Studs / Cam Tower Bolts
GSC S2 Camshafts
ST Dual valve springs
Fully ported cylinder head w/+1mm valves
ACL main/rod bearings/trust
Polished stock crankshaft
Polished metal '08 valve cover
OEM Spark Plugs
Exhaust:
MAP Tubular Exhaust manifold ceramic coated
Invidia N1 Catback
AMS Test pipe
AMS Widemouth O2 Downpipe
MAP EF4 ported
Intake:
ETS Intake
ETS IUCP
ETS LICP
ETS 3.5" Intercooler
AP dual bov
Ported intake manfold
Fuel System:
Walbro 255 Pump
FIC 1100 High Imp Injectors
Boomba Fuel Rail
Drivetrain:
CC 6-puck & flywheel
Misc:
Hallman Pro MBC
LC-1 WB with gauge and serial logger
I've ensured timing is dead on, compression check came back fine, checked all connections and sensors and they're all fine.
Old Apr 8, 2013, 03:06 PM
47 views and no response.
anyway, just came out here and started car. Coolant temp is 68* and idles perfectly. as soon as coolant starts getting above 100 something, then it barely can keep an idle and just wants to stall. especially if you touch the throttle. if you don't, then it idles fine but only if its still running when you first start it cold. meaning, i can't shut it off after warming it up and have it idle fine, and it actually takes a couple rotations to start.
Old Apr 9, 2013, 03:40 PM
any ideas?
Old Apr 10, 2013, 08:28 AM
No help... been searching and reading some potential resolutions but just not matching up. Needing ideas. Oil preassure is fine.
Old Apr 13, 2013, 06:24 AM
Pbayr0lla321's Avatar
Eric I'm thinking it may be related to the coolant temp sensor. I know at work a lot of our Audi's run into this issue, and that sensor is always the culprate. Maybe worth looking into?
- Matty J
Old Apr 13, 2013, 07:39 AM
gsrdc2's Avatar
when i put my motor back in i had a similar issue with it not running right and stalling after it got warmed up. my problem ended up being a bad o2 sensor. just an idea. good luck
Old Apr 18, 2013, 08:52 AM
O2 is new. but, did figure out issue. Was due to oil preassure issue and the ex mivec cam hitting -28* retard. Then figured out what caused the drop in preassure. issue resolved.
EVOEvolved
Feb 28, 2017 01:00 AM
Alchem1st
Jul 30, 2016 01:23 AM
REVOlution86
For Sale - Cars For Sale
Dec 31, 2014 08:39 PM
kawtipin
17
Dec 13, 2013 08:05 PM
gidz
May 21, 2012 08:32 AM
Quick Reply: Idle issue
