Gear shift has lateral movement
Old Jun 11, 2013 | 08:33 PM
bigmatt33's Avatar
I have a works short shifter kit. Something happened and now there is a ton of lateral (side to side) movement in the gear shift. Plus I can't get into reverse it just goes into 4th. Does anyone know what this might be?
Old Jun 11, 2013 | 09:46 PM
bigmatt33's Avatar
It will actually only go from 3rd to 4th. Everything on the short shifter looks ok so I guess it is the transmission.
Old Jun 12, 2013 | 08:56 AM
bigmatt33's Avatar
I hope my transmission isn't trashed.
Old Jun 12, 2013 | 11:10 AM
Kracka's Avatar
Something is loose or not tightened. Did you do any of the bushings at the same time or did you install just the shifter? If just the shifter the fix should be easy...retrace all your steps and find whatever is loose
edub173
May 21, 2016 07:17 PM
vennom
Mar 1, 2016 07:22 PM
ikuto
Dec 9, 2011 04:56 PM
Christoforo
Dec 3, 2008 01:08 PM
toddcfii
Jul 29, 2007 07:42 AM
