OEM Coolant black ... ?
I checked my coolant and its low and almost black ...
Im at 50k km, I'll flush it but what do you think happened ?
I checked everywhere for a leaking gasket or traces of oil in the engine bay... didn't find nothing.
The car is pushing 400hp since 2 years and run great as the first miles ...
I don't think I could do a good picture, but to describe better, I could say it looks like green coolant mix with oil and residue but after 50 000 km, how is the coolant suppose to look ?
Boost from the turbo-- could have been a boost spike, sustained boost of time, detonation, a bad tune, likely either blew out the gasket between cylinders or an oil and water jacket or lifted the head-- , hitting boost when the car is cold, overheating--any of these or all of them. what kind of boost are you running? Do a compression check. Get it to a shop.
I did a flush today.
The coolant was brown/black but if it was oil, would it reflect a rainbowish color ? cause it was brown/flat with no distinction of oil in it.
To my suprise their was a quarter inche of residue in the condenser tank ...
Also, I checked online for blown head gasket problems, and I have none, no leaks, no white smoke, no high temp and the car is running smoooth ...
mitlan
May 15, 2015 08:09 AM
cangri1788
Lancer Engine Tech
Oct 20, 2014 09:56 AM
