Best route to go as far as test pipes...1 whole or 2 separate?
Old Jul 2, 2013 | 12:28 PM
infeKteDx's Avatar
I plan on getting English Racing tuned in August, looking for test pipesssss.
Should I go one whole pipe replacing the DP and cat, or should I just get a test pipe to replace the cat?
Will I be able to drive the car with a DP+test pipe replacement without a tune until I get one?
I currently have intake + UICP and plan to do EBC and test pipe or DP/test pipe + tune. Which would be the better situation, I'm not trying to do anything CRAZY, I'll stop at those mods after the tune, just want some decent power on a conservative tune....so what are most of you running? just a test pipe, or a DP + test pipe?
Thanks for the input!
Old Jul 2, 2013 | 09:02 PM
CainEvoX's Avatar
try using the search feature. this has been brought up over and over again. that being said I run a test pipe and stock Downpipe. ive read that you don't really see much from an aftermarket dp until you upgrade the turbo. definitely plan on getting a tune after installing either or both though. Good luck and enjoy the growl.
Posted from Evolutionm.net App for Android
Old Jul 3, 2013 | 07:36 AM
cpunlamd's Avatar
If you're getting tuned by English Racing, I'm sure they can answer all your tuning questions.
Kevin Lock
Jan 16, 2017 06:55 PM
Evo82
Oct 26, 2015 06:21 AM
Evo82
Apr 18, 2014 10:06 AM
afmafia
Northeast Region
18
Aug 20, 2009 05:42 AM
fromWRXtoEVO
Aug 19, 2006 07:43 PM
