Sponsored by:
Sponsored by: CARiD
dp help
Old Apr 18, 2014 | 05:25 AM
Evo82's Avatar
dp help
does AMS or ETS down pipe replace the cat? i am looking for dp that will delete cat converter..or do i need a test pipe,
Old Apr 18, 2014 | 07:08 AM
Drkramm's Avatar
You want a test pipe
Old Apr 18, 2014 | 07:17 AM
Evo82's Avatar
just a test pipe or with dp
Old Apr 18, 2014 | 07:24 AM
Drkramm's Avatar
Just a test pipe, there are no cats in the x downpipe. Unless you plan on going e85/big turbo replacing the full downpipe isn't really worth it.
Old Apr 18, 2014 | 07:30 AM
Evo82's Avatar
no e85 no big turbo, all i have is ets intake and i was told to get a dp that will delete cat and then get a tune, thats why i asked...thank you
Old Apr 18, 2014 | 07:35 AM
Drkramm's Avatar
Np
Old Apr 18, 2014 | 08:03 AM
JonGonzo's Avatar
Just get a test pipe and a ebcs a long with a tune.
Old Apr 18, 2014 | 08:09 AM
CmakEVOX's Avatar
AMS and ETS does not delete your cat. Cobb has a dp that deletes the cat as well.
Old Apr 18, 2014 | 09:00 AM
Evo82's Avatar
thats what i was looking for..might get Cobb then...if i go with ETS or AMS will i be ok or need to get test pipe...sorry i was looking on google but not much there and thank you again
Old Apr 18, 2014 | 09:43 AM
Sev's Avatar
Sev
The DP doesn't have a cat. If you want a DP and TP once piece, go with the Invidia. It has no cat. For less than $300, you can't go wrong. For the most part, Invidia has some good quality stuff.
Old Apr 18, 2014 | 09:52 AM
Evo82's Avatar
thank you Sev, my car is most stock, ETS intake uicp and a bov, i was told to get dp and a good tune, and i got bit confused...opps...but thanks again i will check it out
Old Apr 18, 2014 | 10:06 AM
alsong2002's Avatar
if your tuner told you to get a dp and not mention to get a tp. i suggest you to run away from him.
your setup is no need to get any sort of dp.
go get a test pipe and 3 port or if you have more cash you can also get a nice exhaust. then after all go get a tune.
Kevin Lock
Jan 16, 2017 06:55 PM
Evo82
Oct 26, 2015 06:21 AM
infeKteDx
Jul 3, 2013 07:36 AM
sp00lin2g
Northeast Region
Jun 15, 2007 12:17 PM
ODUB
Feb 5, 2006 05:53 PM
