small soot markings on inside of heat shield
Old Oct 8, 2013 | 10:58 AM
EEVOH's Avatar
Does this look normal? My exhaust shop who is re installing the exhaust after I had the car in the dealership for some issues bought it to my attention. The dealer probably did not take the heat shield off to inspect. Could this be a blown gasket from the hot side to the manifold?
Based on research I was told that this may just be normal from where the wastegate is?
Old Oct 8, 2013 | 11:21 AM
jhoganusaf's Avatar
its probably the o2 housing gasket. doesnt seem to be a whole lot of soot. i would clean it off and check it again in a couple weeks to see if it builds up again.
Old Oct 8, 2013 | 11:23 AM
EEVOH's Avatar
Thanks. I have the exhaust shop checking the gasket out and doing a smoke test.. just in case.. Others have told me these markings are normal for our cars.
Old Oct 9, 2013 | 03:43 AM
kijima's Avatar
Normal, if the gasket was blown it would be quite brown and burnt looking.
Old Oct 9, 2013 | 04:06 AM
EEVOH's Avatar
The area to the lower left is a little bit of black soot (normal). The area to the lower right is brown, almost like some sort of dried fluid. Not sure what that is but there is not a lot of it.
In either case, I had the gasket visually inspected and they said it was fine. I also had the car smoke tested after the exhaust was reinstalled and all was said to be good
Old Oct 9, 2013 | 04:10 AM
kijima's Avatar
I've got one guy who burnt a hole clean through it after he cocked up an exhaust install.
Your's looks 100% fine.
Old Oct 9, 2013 | 05:13 AM
EEVOH's Avatar
Thank you! Thats why I do the simple bolt ons and let the pro's do most of my work.
haxr303
Jun 4, 2018 08:16 PM
Jp7
14
Mar 21, 2016 09:09 AM
Svendiesel
Apr 12, 2010 09:01 AM
thisxguy
80
Aug 19, 2007 04:43 PM
BigAeVo
Jul 5, 2006 09:15 AM
