Idle Control Valve
Old Nov 24, 2013 | 07:24 PM
sam0329's Avatar
Idle Control Valve
so I got a P0507 code today. Idle was very high and will jump at the stop light. Wont stall because the idle was so high like 1800 to 3000rpm. Did a little search found something called the Idle control valve. Most of the result are for eve 6 to 9. Anybody have a pic how it looks like? Where is it located? Thanks.
Sam
Old Nov 24, 2013 | 07:31 PM
detroit pistins's Avatar
here is how the IAC looks on a CT9A.... maybe this will help!
https://www.evolutionm.net/forums/ev...id-inside.html
Old Nov 24, 2013 | 07:32 PM
sam0329's Avatar
Thx... so he pointed at three different things.... which one is it lol.
Old Nov 24, 2013 | 07:43 PM
only 2 things..lol
at .07 and .22 is the IAC..... if you look thru a disassembled TB you would see the bypass going thru the IAC for regulation. at .14 secs is the throttle position sensor.
Old Nov 24, 2013 | 07:45 PM
sam0329's Avatar
So there's two control valve on the evo x as well? Thx.
Old Nov 24, 2013 | 08:18 PM
in the video he points out the iac twice, so there is only one iac on the ct9a. i would think the evox is similar but haven't seen one to be sure.
Old Nov 24, 2013 | 10:50 PM
sam0329's Avatar
Tuner said there is no Idle control valve on evo x. So could be the throttle replay? I replaced the stock one with SSP relays a while ago.... Like couple months max
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
problem03lancer
Lancer Troubleshooting
Apr 1, 2017 05:45 PM
mrm95
Dec 18, 2013 06:45 AM
edIT
Oct 7, 2011 07:09 AM
SW20Mike
Aug 24, 2011 05:40 PM
