Problem solving 101
Old Dec 30, 2013 | 09:02 AM
2.0T Mirabeau's Avatar
Problem solving 101
I will start off by putting the link to my build thread for those to see some background of the car.
https://www.evolutionm.net/forums/ev...0hp-360tq.html
So onto the things I am needing help with from you experts and seasoned vets. Car started to smoke back in Octbober before I parked it in the garage after I would do a WOT pull. Car never smokes under idle or normal driving conditions. We pulled compression on all four and number 4 was reading low as 96 the rest showed right at 125 to 138.
So my first guess is the ringland is cracked on number 4 but could there be another issue going on. The reason I ask this is because the car runs the exact same only reason I knew there was something going on was the change in idle and the smoke after a pull.
I want some help with the direction I should go so I have a reliable DD with a turbo upgrade and engine build but first would like to talk about the other issues first.
Old Dec 31, 2013 | 04:26 AM
packrat's Avatar
Any oil on #4 spark plug? The next step would be a leak down test and to drop a scope in the cylinders to see if there is anything ugly. How is your oil consumption?
Old Dec 31, 2013 | 10:36 AM
No oil on the plug when we pulled it and oil consumption is very little to none. Leak down is what I will pursue next.
Old Dec 31, 2013 | 01:50 PM
obake214's Avatar
Agree with packrat.. cylinder leak down to see. leaks out of exhaust or intake then have a valve issue. out of the crankcase would have ring issue.. dont see that there would be a drastic failure being you dont have terribly low compression. also you could do a wet compression test..(put small amount of oil in the cylinder).. if compression would raise then ring issue.
boost556
29
Sep 1, 2017 01:34 PM
dumpdbasethound
Oct 9, 2015 02:18 PM
AJsGenerX
82
Sep 28, 2012 06:18 AM
EvoVIII03
13
May 10, 2011 03:43 PM
WRXEM
Nov 29, 2008 06:26 PM
