Maf housing question
Old Jun 8, 2014 | 02:01 PM
powerman00's Avatar
hey guys,
I know this has been asked but I searched and found conflicting advice.
Im currently tuned to 346/356 with:
ets intake
ets uicp
ets 3.5 ic
Cobb BOV
ams dp
test pipe
perrin cb
Grimm 3port
dw65
I have waiting for install:
EF3 turbo
Full race manifold
ID 1000's
Will I need a bigger maf housing to optimize my setup or will the stock work for me. Im hoping for 420whp on a jet with 93 only. Also is my goal too lofty or what can I expect here?
Old Jun 9, 2014 | 09:32 AM
ETS Michael's Avatar
Really depends on the tuner. There is a chance you will hit 5v at high boost. If you use a tuner like ESPEC, you won't need a MAF upgrade, he can run a hybrid speed density calibration and the factory MAF will work fine.
Thanks!
Michael
Old Jun 9, 2014 | 04:30 PM
powerman00's Avatar
just looked at my log of my current tune and im hitting 4.6 at 26lbs boost. Would you recommend I go with a bigger maf to be safe or can I get away with it? Im not on a strict budget and if will yield me more hp then im all over it.
Old Jul 16, 2014 | 01:04 AM
AWDXTCY's Avatar
Moore Automotive sells a 3.5 inch intake for $250-ish? It comes as a full kit for the EVO X but you will need maf calibration which is pretty esay. I hit 4.7 volts at 25 psi with S2 cams using the factory maf housing and ETS intake. The Moore unit has been on their shop car making over t hp so it's pretty much the last intake you're going to use...
Old Jul 16, 2014 | 08:06 AM
We offer a 3.5" maf housing as well.
http://www.extremeturbosystems.com/E...F-Adapter.html
Thanks!
Michael
Old Jul 16, 2014 | 12:05 PM
Hiboost's Avatar
General rule of thumb on a Dynojet:
Stock 2.7" = 450 whp
3.0" = 500 whp
3.5" = 600 whp
4.0" = 700 whp (or just go Standalone...)
Old Jul 23, 2014 | 11:48 AM
sparky's Avatar
Originally Posted by ETS Michael
We offer a 3.5" maf housing as well...
Is this housing plug & play, Mike?
Old Jul 23, 2014 | 12:06 PM
Yup!
JohnBradley
Evo X Dyno Results
May 1, 2016 08:10 AM
AWDXTCY
Mar 2, 2016 03:29 PM
shekaar
May 8, 2015 01:23 PM
AWDXTCY
18
Jul 25, 2014 10:29 PM
Boost3dxEvO
Nov 6, 2007 09:51 PM
