low oil pressure warning after freeway
Old Jun 27, 2014 | 11:00 PM
wonkaa's Avatar
when coming to a stop after driving on the freeway or 60+ mph for an extended time I keep getting a low oil pressure warning. The engine doesnt stutter or do anything odd other than the warning. If i turn the car off and let it sit for a minute then start it again the warning doesnt come back on. Even after spirited driving it wont come on, only after doing 60+ for a while then coming to a stop. anyone know what could be causing this and how to fix it?
specs: 2013 gsr 8,000miles
AMS DP, 3" testpipe, 3" catback , 4" depo intercooler, full hard pipes, K&N cone filter, grimmspeed 3 port
Old Jun 28, 2014 | 02:06 PM
zebra4's Avatar
Stupid question, did you check your dipstick?
Old Jun 29, 2014 | 09:39 AM
wonkaa's Avatar
yeah my oil level is good and i just did an oil and filter change change yesterday
Old Jul 1, 2014 | 10:49 AM
wonkaa's Avatar
noone?
Old Jul 5, 2014 | 11:56 AM
Thomar's Avatar
check oil pressure with a mechanical gauge. if oil pressure is ok, replace the oil pressure switch.
Old Jul 5, 2014 | 12:40 PM
EVO KNVL's Avatar
I had a similar issue on my 9. It was the pressure switch like the previous poster have said.
Old Aug 22, 2014 | 10:42 PM
wonkaa's Avatar
where is the pressure switch located?
Old Aug 26, 2014 | 10:48 AM
Burnhad91's Avatar
It's underneath the intake manifold threaded into the block. There is a bracket that stabilizes the manifold that needs to come off and then it should come out pretty easily.
Old Sep 11, 2014 | 03:06 PM
IRPerformance's Avatar
Get a mechanical gauge and verify the pressure. Its its in spec then replace the sensor. DO NOT drive the car with the oil pressure light on. I had a customer that did some of his own work and left a rag in the oil pan during a re-seal. It got sucked up into the oil pump pickup. The oil pressure light would come on randomly. He kept driving and ended up seizing and snapping a camshaft.
Old Sep 30, 2014 | 03:44 AM
OkinawaFD3S's Avatar
He forgot a rag in the oil pan, sealed it up, and ran it?! That must have been awfully embarrassing for him.
Old Sep 30, 2014 | 08:24 AM
Yep. Clogged the oil pickup after a few miles. Destroyed the whole head.
Old Sep 30, 2014 | 02:42 PM
.M.'s Avatar
.M.
^Damn
BostonGTR
Mar 10, 2021 08:39 AM
CottageLifer
Outlander Sport
110
Nov 28, 2016 07:06 AM
Weathergeek
Sep 8, 2016 12:41 PM
MarcK73
Mitsubishi TC-SST Discussion
Apr 6, 2016 08:17 PM
GVO_VIII
Jul 15, 2014 04:32 PM
