Evo Camshaft Sensor P0365 CEL
Old Feb 9, 2015 | 06:50 PM
Luminox's Avatar
Hey, so i got a P0365 code that poped up when i was at idle. The car is lightly moded and tuned. I didn't drive the car hard that day at all. I cleared the code but it comes back after a few seconds, i re-flashed my ECU but it didnt work, tried cleaning the connector and it didnt work either. The car is running fine at idle and cruising, but for now i stay out of boost until i know if having a busted sensor can **** my **** up. I checked my timing chain while i was checking to see if the timing skiped a tooth, but the chain is way to tight for that to happen. Im thinking either my sensor is dead or ECU took a dump. Let me know what you guys think, and if it's safe to continue and drive it as usual (in boost)
Pics
Video of the chain :
Old Feb 23, 2015 | 09:44 PM
IRPerformance's Avatar
Turn the motor over until the - marks on the cam sprockets face each other and the TDC mark on the crank pulley is over the indicator cast onto the timing cover. The exhaust cam position sensor like to take a dive because it is so close to the manifold and sees too much heat. There are heat shields available for it.
Old Feb 25, 2015 | 01:12 PM
hispanicpanic's Avatar
i have extra cam sensors available fyi, if u need one, pm me
Old Mar 8, 2015 | 07:25 PM
Luminox's Avatar
Ended up replacing the Exhaust cam sensor and made a steel heat shield + heat reflective tape on the wire/ Sensor
Old Mar 20, 2015 | 08:22 AM
Fubfer's Avatar
been dealing with this dreaded p0365 camshaft position sensor code for about 2 months now. spliced in a new harness and the new sensor by the manifold is only about 3 months old. anyone have any ideas or cheap sensors leftover?
Slickonice
11
Jan 13, 2013 09:06 AM
hayaboosted
May 7, 2011 09:43 AM
hear_no_evo
Apr 11, 2011 11:06 AM
evil6819
Mar 3, 2011 05:43 AM
evil6819
Feb 1, 2011 08:38 AM
