Setup reccomendations?
Old Mar 20, 2015 | 06:26 AM
hispanicpanic's Avatar
Looking for a reccomendation on a turbo setup.
Car is a 2010 /w SST. As far as use, I track my car and autocross it heavily. What i'd like to do is increase the power output, but i don't want to have to crack open the SST for modifications, so i'd like to essentially see what i need to do to safely take the transmission to the limit, yet be able to do so on track reliably.
So far, my thoughts on this include the following
MHI- 18k turbo
Moore Automotive 3.5inch intake
Full race exhaust manifold
ID 1000cc injectors (93 pump only)
Walboro 255
synapse DV
ETS 3 inch intercooler.
AMS TMP cams (Maybe. Mainly to try and prevent TQ dropoff at redline)
Car will be tuned at Kozmic on their mustang dyno. I'm not sure what he normally reccomends as a safe limit for stock clutches, but i immagine its somewhere between 310 and 340 tq. My goal is to hit this tq number, whatever it is, and try to hold it flat as long as possible.
Your thoughts?
Old Mar 20, 2015 | 01:45 PM
ddlopresti's Avatar
That seems like a good list of mods for your goals, e85 not available?
Old Mar 20, 2015 | 05:34 PM
IRPerformance's Avatar
Have you considered a gtx3071? A trans cooler will definitely help if you plan to autox.
Old Mar 23, 2015 | 06:11 AM
SSP front mount trans cooler already in place. Auto-x is not my focus. I only auto-x to test and tweak my track setups. Tracktime is why i live
I'm already tuned to 300 whp with basic boltons on a stock IC and turbo.
I sourced a used full race mani + MHI for 2200. If i got a GTX, i'd probably be spending a bit more including all the extra lines and bull**** i'd probably need. I'm sure a GTX would perform better for the power level, but i'm not convinced on the idea mainly because of cost and additional things needed to make it work.
Old Mar 25, 2015 | 10:19 AM
NeedBoost!'s Avatar
The FullRace manifold is only really going to produce gains for you if you go e85 and bigger injectors. 1000cc and pump gas on a stock block, even with the best stock frame turbo we can get (the wonderous MHI ), the manifold will actually "hurt" the feel of the car - you will loose spool up time. There might be minimal gains up top but I've never seen a before/after FR Mani dyno sheet that shows where the justification for a $1200 retail piece comes from. E85 and bigger injectors and you have an entirely new story.
Just my two cents...
Also, I don't see an exhaust in your list. You will need a good o2/downpipe, full 3" turbo-back setup.
Don't worry about drop off if you go with the MHI. Look up any thread where a dyno sheet is posted (mine for example haha) and you will see the thing never runs out of breath (unless you want > 8k rpm redline) with the right supporting boltons.
Old Mar 25, 2015 | 11:25 AM
doom26464's Avatar
FR mainfold is one of the few that doesnt show loss in spool with some really nice gains up top compared to other manufactures mainfold which sometime do loose spool.
I love my FR manifold.
Old Mar 26, 2015 | 05:46 AM
Ok so, forgot exhaust. I already have a full titanium exhaust from downpipe to muffler.
I don't want to go e85 because 1) there's no e85 on track, and 2) i'll already be maxing out my mid range tq. There's no need for e85 unless i want to control tq drop off a little more up top. If there was e85 on track, honestly, i'd be on e85 already.
The reason why i want Full Race is because they're the only company to offer a lifetime warranty on their manifolds. Considering how often i race and the propensity for EVo X manifolds to crack, This little bit of insurance is worth EVERY penny.
I spoke to Kozmic and they reccomend the FP green over the MHI. Not sure why. I thought you couldn't buy fp turbos anymore?
Old Mar 26, 2015 | 01:00 PM
Fiji_boss's Avatar
You will have to send in one to be modified.
Old Mar 27, 2015 | 05:21 AM
send in a perfectly good stock turbo?! then i hand over damn near 2k? Sounds like a rip.
Old Mar 27, 2015 | 11:43 AM
alsong2002's Avatar
couldn't agree more. by all the other opitons out there, the price for the fp upgrade is so over rip.
Old Jun 1, 2015 | 03:43 PM
NeedBoost!'s Avatar
The guys at FR even tell you that you will lose at least 200-300 rpm in spool up. Most people have seen 30-40hp increase up top which is why there are a lot of happy customers - forgiving the slight lag increase for the pretty dramatic increase up top. I've experienced a few hundred rpm increase in lag just based on different turbos and can say that it makes a world of difference to me. But that's me, not everyone cares about the same stuff i do.
Old Jun 1, 2015 | 03:51 PM
NeedBoost!'s Avatar
The MHI is co-designed by FP. I don't know what more us stock-frame turbo guys could ask for really.
Old Jun 2, 2015 | 12:44 PM
Volkey's Avatar
I would absolutely get the 18k over a green.. Did your tuner explain why he thinks you should go the green route instead??
05evo
Aug 9, 2005 06:39 PM
Soon2BEVO
15
Dec 30, 2004 07:12 AM
Evo442
Mar 28, 2004 04:32 PM
