wastegate AGP (RED SPRING)
hi this is my car.:!! EVO X 14 GSR
Hello guys, this is Oliver.:!!
I just buy a AGP WASTEGATE and i want to install the red spring (25psi), but the problem is that at the time of when push gas (WOT) i have CHECK light, and enters LIMB MODE ... how i need to do to keep me the PSI in the top as much as possible and that they do not fall so down..?? or definitally have to get back to OEM WG..????
Don´t have any leak, The WG rod is stretched .....
hope you can help me
I have STAGE 3 (COBB)
Turbo back
K&N intake
Boomba TB 75mm
Turbo Manifold
1000cc Injectors
AGP IC
LPIC
GS EBCS
competition STG 2 clutch
"AGP WASTEGATE"
Thanks in advance..!!
http://i1174.photobucket.com/albums/...pshuxi4q9h.jpg
Turbo back
K&N intake
Boomba TB 75mm
Turbo Manifold
1000cc Injectors
AGP IC
LPIC
GS EBCS
"AGP WASTEGATE"
I'm going to go out on a limb and assume since you're running an OTS map with new injectors, wastegate and TB, you're not tuned for any of that.
I'd suggest getting professionally tuned before something negative happens.
FS[West]: AGP wastegate actuator w/ 19psi spring
e_kobz
May 7, 2015 07:22 AM
EvolvedAK
Oct 10, 2014 04:22 PM
tico915007
Aug 7, 2011 12:36 PM
vigilante.zen
40
Aug 27, 2010 08:01 AM
