Exedy Stage 2 + Exedy Lightweight Flywheel
Old Nov 10, 2015 | 08:01 PM
alfredoaal's Avatar
Hello, I've replaced my stock clutch disc with Exedy stage 2 (4 puck) + Exedy Lightweight flywheel. My car is making this weird sound after installing this parts, it is not only sound, the clutch pedal vibrates a lot and it feels like the disc is slipping. I have this problem only when parking or after a complete stop.
I know puck discs are not like stock, but is this normal? I feel like something is breaking.
Old Nov 11, 2015 | 09:14 AM
hoobastnk90's Avatar
Yea that sounds weird I would take that back to whomever did it.
Old Nov 11, 2015 | 05:57 PM
alfredoaal's Avatar
The dealershio did it, I will have to take it again.
Old Nov 14, 2015 | 12:58 AM
cocobobo20's Avatar
No this isn't a problem trust me when i was first getting this is was going crazy i even talked to exedy and they told me it's perfectly normal. Mine does exactly this but it's not all the time some times it happens
Old Nov 14, 2015 | 12:10 PM
alfredoaal's Avatar
The dealership said this is normal, I can't believe this, This clutch kit cost me a lot and my car is like crap. I think I will go back to OEM clutch disc.
Old Feb 9, 2016 | 01:40 PM
Krytical's Avatar
Hi, this is normal. I can assure you of this. You have a 4-Puck clutch. You will have this chatter more audible than you will or if any with the full face clutch. It's perfectly fine. It takes time to get used to it. If you really don't like the sound, you have to rev higher or slip it slightly to get it to go. One reason is because it really grabs harder, and you're not letting go quick enough. You know that saying "Go or No-Go?" This is it. I have a 6-Puck as well and before I got it I made sure to do a lot of research before heading this direction. A search on google with 4/6-puck clutch chatter should show you common incidents of like-minded people inquiring about the same situation. No problems, you'll be fine.
Old Feb 9, 2016 | 02:52 PM
Chef-j's Avatar
aftermarket clutch and flywheels makes all kind of noise.
Old Feb 10, 2016 | 12:44 PM
alfredoaal's Avatar
I went back to the OEM clutch and flywheel, exedy is crap. I've read 6 puck are better, maybe my next clutch will be a 6 puck but I will search information before buying. Thank you.
Yes, I should search about this before buying an aftermarket clutch. Thank you
Old Feb 10, 2016 | 01:56 PM
damn son so you paid for 2 clutch jobs!
Old Feb 11, 2016 | 05:24 PM
alfredoaal's Avatar
Yes I did
Old Feb 15, 2016 | 07:01 PM
Krytical's Avatar
Originally Posted by alfredoaal
Yes I did
Bro you do know your Stock OEM Clutch is Exedy right?
Old Feb 16, 2016 | 05:14 AM
alfredoaal's Avatar
Yes I do and I think is not a good clutch but is still better than the stage 2 clutch, what I meant to say was "exedy stage 2 clutch for Evo X is crap"
I had a 3 puck exedy on my Honda Prelude and never had this problems, also had a honda civic si with stock clutch (which I think is exedy) and never had to replace it, but i had to replace my stock clutch on the Evo X after 10 months.
Old Feb 16, 2016 | 09:09 AM
Yea those 3 puck or 6 puck clutches are not my favorite, I had bad luck with those in a few of my Hondas. Had great bite but didn't last that long. I'll be sticking with full disc clutches when it comes time for me to do the evo clutch as well.
Old Feb 22, 2016 | 12:21 PM
HatrixMouse's Avatar
Dude, Exedy is not crap - it's who made your OEM - you just have no idea what a 4/6 puck clutch and lightweight flywheel combo are supposed to feel/sound like. Do you think you're going to have the same drivability as stock? No. If you wanted some form of DD ability, you'll need to go with a full-face clutch. a 4/6 puck is for racing application or high horsepower due to the clamping force and grip.
So don't blame a manufacturer because you went over the top on a clutch and regret the harshness of a part for performance. Blame yourself for being naïve and thinking you could install a 500tq+ capable clutch that drives like stock.
Old Feb 23, 2016 | 09:16 AM
alfredoaal's Avatar
I have driven an Evo X with ACT 6 puck clutch and it is a night and day difference against exedy stage 2, both are race clutchs but the ACT doesn't feel/sound like exedy.
Of course I don't expect the same drivability as stock because I'm installing a race clutch, but the feel/sound with exedy really sucks. With the ACT it doesn't sound at all. It is MY opinion.
Yes I have to blame myself for no looking information about this topic before buying.
