Stock Turbo + Meth or MHI 18k?
While planning my build for spring I am debating whether it is best to add meth on the stock turbo or ditch the meth and just get an MHI 18k?
The catch is I have an MR and don't want to replace the stock clutch packs for a least a few years. I have an AMS trans cooler and will have a SSP heated sump, so I figure that should help longevity.
Also please note this would be with full AMS bolt ons on 93 octane with an open source tune.
My thinking was by adding meth we could compensate for some of the stock turbos "high rpm fall off" by adding additional timing when the meth came in. I figured we could control the timing in the tune to keep any extra torque spike under control so the SST is happy. Plus I've always wanted to have a car with meth (silly I know, but hey might as well build the car for you)
On the other hand the MHI 18k would spool slightly slower (SST should be able to deal with it given torque spike is less than stock turbo) but would hold power much better up top.
In an ideal world I would hit about 380 whp and 350 wtq (I figure that's about as high as I can go and still be safe on stock SST and block and I know that HP number might be wishful thinking). Given those limits is why I originally was going to stick with the stock turbo.
Your input is appreciated.
Do the MHI 18k, and have English Racing tune it. Aaron can tune the SST to hold torque that is the safe limit for the stock short block, so you'll be good on the trans. I wouldn't mess around with meth, just seems like a hassle.
Any recommended SST capable tuners near NJ?
Doberzus
Dec 28, 2013 11:47 AM
MRevo9
13
Aug 26, 2013 01:47 PM
1d10t
11
Mar 4, 2010 07:10 AM
