Competition Stage 3 Clutch Review
2010 EvoX GSR
Miles: 62856
Clutch: Competition Clutch Stage 3 5153-2600 series
Mods: Injen Intake
Hi everyone so I had my clutch recently replaced on my 2010 EvoX GSR. The stock clutch had 62800 miles when it started slipping. I had the clutch replaced at 62856 miles and am in the break in period now.
I had the work done by Kaizen Tuning in Boxborough, Massachusetts. I was recommended to go with the Stage 3 since I plan to get Eva up to 400hp after my next assignment. The clutch feels completely different than stock. The engagement point is about 2-3 inches from the floor compared to stock which is about 6-8 inches. Its almost like having to learn how to drive all over again but it isnt too bad.
Once I finish the break in I will post some more about the clutch and how it feels, if Ive had any lock out issues, etc.
Update: 2/9/17
So today I drove down to Norfolk, VA from Worcester, MA. Let me tell you that was one hell of a drive. Took me 13 hours because of the snow storm today. Anyways I used this drive for breaking in my clutch. Now I know long drives arent the best way to break in a clutch, but because of the snow I did have to change speed and shift a lot. So that helped with that. I also had to change speed a lot when I got to Delaware because I took the 13 which was nothing but going from 55 to 45 mph and back and having to stop at the lights. I did my best to keep it out of boost when accelerating. There were only three times where I hit higher then 9psi so thats not too bad. My pedal issue seemed to take care of itself. It actually feels great now. The clutch definitely grabs better than stock. I havent had a chance to actually get into a high rpm range since I just broke it in but that will be happening this weekend.
Miles: 62856
Mods: Injen Intake
Update: 2/9/17
Update: 2/12/17
I drove around yesterday and did some pulls and shifts. I was able to shift above 7000rpm without being locked out. The car feels great with this clutch.
Thanks for sharing this, any more info highly appreciated!
Looking at this clutch now as mine started slipping at 55K miles.
Letsgetthisdone: while the clutch is being replaced, do you recommend doing other things other than the 60K service?
If you don't have an O2 eliminator/down pipe yet, those are easier to install with the passenger side axle removed.
^Thanks LGTD!
The shop where I take my car said the CompClutch stage 3 kit comes with an OEM throwout bearing. And when I asked for the ACT monoloc collar upon installation, they said that is no problem but that would void Competition Clutches warranty.
So I'm going to let the shop install everything as they recommend so they can stand behind their work and product.
I was going to have the CMC upgraded to the AMS CMC but they said since my car is a 2014, it's not needed.
Very nervous to be honest for this install as i've never had a new clutch installed on any of my cars. And I have a 12hr road trip with the car the following day.
Hi everyone sorry I've been away. I was waiting till 5000 miles to update but since you asked I am at 67xxx miles. Almost 5000 since I had the clutch installed and so far I've had no problems. Granted I don't launch my car but I do drive it pretty hard. I've had no lock out issues and I've shifted when the fuel cut out because of the limiter. Once the clutch is broken in it feels real nice and almost like stock. I still recommend this clutch to those looking. There is some noise and chatter but not much I can do about that. You honestly can't hear it when you are driving with the radio on. Other than that it is a good clutch.
^Thanks LGTD!
Or did you just use what came with the clutch kit?
Thanks for the reviews!
