Evoscan AYC Codes. Help?
Old May 28, 2017 | 03:17 PM
supwiddiss's Avatar
Service light came on a week after an ecu tune.
Pulled the codes with Evoscan v2.9.
I can clear them and the same ones come back shortly after.
Codes:
c00a0
c1290
p20c1
c1242
p20ff
Car is parked inside during winter, 2012 GSR with 30k miles sporting a Buschur sleeved 4B11T. Looks like a G sensor at the very least from the shop manual. Can anyone assist in diagnosing? Trying to locate the AYC computer and sensor that may be the culprit.
I cleaned the car and pressure washed the ACD pump area.
Could really use some help here before I find a dealer and flash back to stock.
Thanks!
Old May 30, 2017 | 11:49 AM
ddlopresti's Avatar
i recently had a g sensor fault code, same one as you. The sensor is located beneath the center dash (access from driver's footwell is easiest) You have to pull back the carpet that runs up the footwell on the right where it start to come up to the center tunnel and its behind there. I have a pic on my phone i can text you if you need it. Shoot me a pm if u need more help locating it.
blowngasket
Jan 22, 2016 09:23 AM
stunt2
Jan 31, 2012 07:45 AM
HiRevnVIII
Mar 1, 2010 05:58 AM
Evo8Emperor
Mar 13, 2008 01:00 AM
expl0d
Jul 17, 2005 05:12 PM
