MAPerformance vs other drive train companies
Old May 29, 2017 | 04:33 PM
FluidmotionA9's Avatar
Veteran: Air Force
I have the build i want in mind down to the hardware and I was going to go with MAPerformance but I just finished talking with some guys on an Evo X page and they are saying to go with English racing. I can't find any good threads or reviews comparing them. I am looking for something that can hold 800-1000HP. It is all depending on how well they build their blocks and cylinder heads.
P.S. I see MAPerformance basically has a grasp on this site which worries me that they are just pumping their products.
Old May 29, 2017 | 05:10 PM
rosuegk7's Avatar
Wrong board, mate.
Old May 29, 2017 | 07:21 PM
V.8MR's Avatar
If I'm not mistaken, MAP uses TRE... But thats a vague memory or rumor I heard.
Edit, you are talking about a motor build. Also this should be in general or engine/turbo/drivetrain...
Old May 30, 2017 | 07:54 AM
Veteran: Air Force
ok thank you
Old May 30, 2017 | 08:08 AM
Will move your thread to: Evo Engine / Turbo / Drivetrain
You may get more useful comments there!
Old May 30, 2017 | 09:30 AM
LetsGetThisDone's Avatar
Stay away from MAP. Send your trans/tcase/rear diff to TRE if any of those need going through.
If you need an engine, buy an engine from a company that actually uses/races the engines they build and are selling you. MAP does not do this. English Racing, Buschur, Curt Brown, or Boostin Performance are great options.
Check out the last few pages of this thread to see why you should avoid MAP. Pal215's engine was broken in and tuned properly, and still had issues. Once he posted the build sheet, it was easy to look at the numbers and see that the thing was completely pencil whipped and likely does not represent any of the actual size/clearances inside the engine.
https://www.evolutionm.net/forums/pr...ack-build.html
Worth noting, ER has the record holding Evo X/4b11. They know all the tricks to keeping the 4b11 reliable/together.
Old May 30, 2017 | 03:37 PM
Veteran: Air Force
Hey thanks man this helps a ton
PorkRoll
Jul 1, 2009 06:23 PM
TomG
Feb 23, 2005 04:22 PM
EvoRSX
Jun 8, 2002 07:29 PM
