Rear O2 Sensor Replacement
Old May 29, 2017 | 02:42 PM
vendetta92's Avatar
Bought a used EVO X last week and it has a vibrant exhaust which is missing the rear O2 sensor so I have a CEL. Need to pass Ontario emissions so I need a replacement rear O2 sensor then the shop will install it for me & pass my emissions. OEM is $600, just wondering if this $177 replacement the correct part, plug & play or does anyone have any links for other versions of the same parts. Thank you. 2008 EVO X GSR.
https://www.densoproducts.com/product.aspx?zpid=18076
Old May 29, 2017 | 03:51 PM
.M.'s Avatar
.M.
That's the correct part number. Local part stores are selling them for around $250ish around here.
Old May 29, 2017 | 04:19 PM
vendetta92's Avatar
Thanks for the reply. Does this also look like the correct part, would save me the time waiting to ship which would be nice. https://www.napacanada.com/en/p/NGB25693#
Old May 30, 2017 | 05:36 PM
Rasperin's Avatar
Not the answer you are looking for, ngk looks like it is using the right plug. If Napa confirms it it should be fine, another fine alternative is:
Amazon Amazon
Or the best alternative, just disable the sensor if your planning on modding your car, I believe goldens images have the disable rear o2 built in.
Old May 30, 2017 | 07:18 PM
Cflo23's Avatar
5 Year Member
Its okay to use aftermarket o2 sensor's for the evo x rear ?
Old May 31, 2017 | 09:46 AM
Rasperin's Avatar
@Cflo23, I haven't replaced mine as I just straight up disabled it. However, most parts these days talk on IEEE (aka a standard format approved and registered with the IEEE) style encoding to the ECU so as long as the adapter and language is right there should be no problems.
In short, it should be fine.
Old May 31, 2017 | 11:27 AM
Cflo23's Avatar
5 Year Member
Thanks Rasperin, the reason I ask is I stripped the threads on my oem rear o2 sensor while installing my cobb catted test pipe. I was able to fix it with a o2 sensor extension, but not sure if it will be salvageable once I take it off again down the road to install a catless ets test pipe.
I also don't like the fact that I have my oem o2 sensor to a o2 extension than to the test pipe, rather than just have the o2 sensor directly into the test pipe.
I have no check engine lights of any sort and I have no exhaust leaks. Thus I think the o2 sensor extension should suffice until I purchase a brand new sensor just for my personal well being.
Old Jun 7, 2020 | 03:14 PM
Drew Boo's Avatar
I got the same code what did u do to fix it ?
I got the same code I fixed the spark plugs new battery and fuel injectors and new o2 sensor what’s next ? I keep gettin code 145 for 2011 lancer 2.4 Es . Mechanic said car was good and sensor was good ? Maybe a ecm reboot ? would help if answered fast because I need pass smog thanks
steven88
18
Feb 20, 2018 07:03 AM
dana daray
Jul 1, 2015 07:25 AM
Cru
Oct 25, 2011 05:23 PM
EVOMIZ
Mar 19, 2004 08:34 AM
