First upgrade to do with my evo x?
Old Jun 25, 2017 | 12:08 AM
kingjhay723's Avatar
hey fellas, upgraded myself to an evo x from 04 RA,,,
now Im thinking puuting money into my car,, im notice that my throttle response is slow... When I step on the gas pedal the acceleration takes forever to pick up. anything to suggest?
and what does a throttle booster do? (heard it from someone with a civic)will that help throttle response? thanks for helping out a new evo x owner!
Old Jun 25, 2017 | 03:21 AM
DRAGHICI's Avatar
Is the clutch okay?
Id start with A stiffer engine mount that will stop your engine from playing basketball and will feal more responsive!
Metal shifter bushings too if your a manual.
Old Jun 30, 2017 | 11:31 AM
Schwingy's Avatar
Probably has absolutely nothing to do with it but may want to check spark plugs as well just food for thought if you haven't changed them already
Old Jun 30, 2017 | 01:37 PM
splattj's Avatar
Did you go from an RA to a GSR or an MR? RA to GSR you're going to notice turbo lag. The Evo has a bigger turbo and takes a bit longer to spool.
There are at least a dozen threads about first mods that you should take a look at. Quick answer is a 3-port boost controller and tune.
Old Jun 30, 2017 | 02:35 PM
4b11slayer's Avatar
intake or drop in filter
down pipe
3 port
e85 tune
GO ON 3
Toronto Lancer Club
20
Mar 1, 2011 02:29 PM
David Buschur
41
Jan 5, 2009 10:24 AM
smoke4
Oct 19, 2008 10:18 AM
Boost3dxEvO
Sep 24, 2007 03:44 PM
MalibuJack
25
Oct 21, 2004 11:33 AM
