need help with identifying this engine rattle. it only does it while the car is warm. it only does it while over 1500 rpms and its a steady sound. could it be the timing chain car only has 50k miles
https://www.youtube.com/watch?v=67cY...ature=youtu.be
2006EvoIXer
close
- Join DateJul 2012
- LocationCalifornia
iTrader Positive Feedback100
iTrader Feedback Score(1)
Liked:197 Times in 185 Posts
Sound like you have an exhaust leak.
kaj
close
- Join DateMar 2006
- LocationFresno, CA
iTrader Feedback Score(60)
Liked:824 Times in 685 Posts
If you are having trouble finding the source, you can Grab a stethoscope from the autoparts store. I use the tubing to track down where the sound is coming from (and vacuum leaks), then the metal probe, if i need to check areas for bad bearings, vibration, etc.
They are worth the money.. I use mine all the time.
