MAF Sensor Blues
MAF Sensor Blues
Thought I would share my MAF sensor experience with the forum. I have an 08 X with breathing mods and AMS tune. Started getting codes for the MAF (out of range, etc.). Cleaned it, reset codes, but they always came back.
I replaced the MAF sensor with a $70 "drop in" replacement. Worked for a while, then the car periodically did not want to accelerate at all with frequent bogs/hesitation. AMS helped diagnose a bad MAF sensor (dealer could not figure out the problem). So I replaced it again with another $70 variant. The car ran, but didn't ever feel right. Not snappy and quick, and still had periodic bogs for no reason. See attached plots of log data. The MAF sensor was clearly not working properly again.
Replaced the sensor with an OEM version, and I'm back to normal beast mode.
OEM and aftermarket variant look similar, but the elements are clearly different. Seems as if the OEM is much more robust.
BOTTOM LINE: Beware the cheap MAF sensors. I'd recommend going with the Mitsu product.
93HardTopTurbo
Apr 26, 2009 02:11 PM
