Turbo removal
Old Oct 8, 2017 | 05:46 PM
porovoz916's Avatar
Turbo removal
Best way to remove turbo. Pulling engine out or keeping it in? People saying there are hard bots to reach.
Old Oct 8, 2017 | 06:26 PM
Chef-j's Avatar
You dont need remove engine. Manifold, down pipe and Testpipe or HFC.
Here is DIY. This helped me ton.
https://www.turbobygarrett.com/turbo...tions_RevA.pdf
Old Oct 11, 2017 | 05:59 AM
static_set's Avatar
That's an awesome resource. Good looking out!
-ash
Old Oct 11, 2017 | 10:36 AM
bolothedv's Avatar
The bolt in Fig 20, Page 11 was a pain in the *** for me to get out.
Old Jan 21, 2018 | 01:06 PM
Cloud9tribe's Avatar
Youtube is a good friend. Depends how many miles is on there, Buy new studs, bolts, hardware. The hardware gets old and welded together from the heat. Threads turn into ****.
A torch is a good friend when removing exhaust side bolts.
Old Jan 21, 2018 | 01:37 PM
e_kobz's Avatar
Be sure to saturate everything with PB blaster the night before you’re planning on doing the removal. A good size breaker bar will help too.
Old Jan 21, 2018 | 01:38 PM
e_kobz's Avatar
Agreed. The damn bracket bolts are the absolute worst.
Old Jan 21, 2018 | 02:44 PM
►EvolutionX◄'s Avatar
Use a shallow socket with a wobble socket extension to remove this bolt easier... unfortunately I've had my turbo on and off my car about 10 times, so I'm a little accustomed to removing these hard to reach bolts.
Old Jan 21, 2018 | 02:58 PM
e_kobz's Avatar
That's what I did too. The first initial removal of the stock turbo was the worst. Once all the bolts were off I put anti-seize of everything. Now the removal isn't that bad anymore.
Old Jan 21, 2018 | 03:12 PM
Yup. Do yourself a huge favor too and buy a thread chaser for the turbo bolts. Clean the threads and inspect ALL bolts prior to reinstalling. You will thank yourself for doing it in the case of future removal.
6-speed
Sep 10, 2007 08:26 PM
SuPeRNeT
12
Jan 24, 2007 09:54 AM
Ink
12
Jul 25, 2006 06:59 AM
dakind916
Jun 30, 2006 07:40 AM
BadBoyBeltran
Nov 24, 2003 06:57 PM
