p0171 and burnt clutch
Old Oct 13, 2017 | 10:55 AM
SpeedI2acerX's Avatar
So I was accelerating on the on ramp and I believe I finally killed my clutch 76k on the stocker. I can smell burnt metal while driving and I'm pretty sure it's the clutch but I'm also getting a P0171 code, how is that related to the clutch? I was on 5th And the rpm shot up and I thought I was on neutral.
Old Oct 13, 2017 | 02:30 PM
whtrice's Avatar
Veteran: Air Force
Well clutch is a goner for sure. P0171 is not related to your clutch issue. Tell us a little about your car...tuned? ..... mods
Old Oct 13, 2017 | 07:21 PM
Mods are full bolt on gtx3576r, flex fuel, 2000 injectors, and dual pump. I've haven't had any issues til now.
Old Oct 14, 2017 | 04:20 AM
whtrice's Avatar
Veteran: Air Force
If you had an AFR gauge it would show if you are running lean. P0171 is system running too lean in bank 1. Some suspects are a dirty MAF, vacuum leaks and exhaust leaks. If these all look good through inspection then I would seek out a good tuner in your area for help.
emuleiii
May 23, 2018 08:04 AM
3SgteGuru
May 11, 2007 03:20 PM
Kazoo's1st Evo8
16
Jul 4, 2003 05:05 AM
EvoAndyUK
Jun 18, 2003 09:17 AM
