Hardware for turbo swap
Old Jan 22, 2018 | 06:59 AM
jakgal04's Avatar
With my 18k on the way, I'm prepping everything I'll need for the swap. I'm referencing the Garret install guide, but it doesn't mention things like manifold bolts or turbo to manifold studs.
What parts do you guys recommend I replace or reuse? I'm assuming it would be best to pick up some new turbo->manifold bolts. What else?
Old Jan 22, 2018 | 09:30 AM
4b11slayer's Avatar
your likely gonna break some studs on the down pipe.
you can reuse the manifold to head bolts and nuts. those usually dont seize.
I would add a stainless steel lock washer on all the head to manifold bolts.
Plan ahead and spray all exhaust related bolts. And i mean soak them. Not 1 hour before removal but a day of soaking.
If you remove a bolt and feels like its getting hard to turn re tighten it to help clean threads. If you force it out the nut or bolt may break or damage threads.
Old Jan 22, 2018 | 09:52 AM
jakgal04's Avatar
Good to know. I'll be soaking the bolts down the day before, and I have a torch ready for any PITA bolts. I have a MAP downpipe installed, but I'll definitely be picking up some replacement bolts in case.
Old Jan 22, 2018 | 10:08 AM
RazorLab's Avatar
100% get new OEM lock washers and MAKE SURE you install them correctly.
Old Jan 22, 2018 | 10:28 AM
jakgal04's Avatar
Thank you!
So far the parts list includes:
Turbo > Manifold gasket
Oil drain gasket
2x 10mm copper crush washers
2x 12mm copper crush washers
4x 14mm copper crush washers
4x Manifold bolts
4x Manifold crush washers
5x MAP downpipe bolts
Am I missing anything?
Old Jan 22, 2018 | 10:36 AM
e_kobz's Avatar
A cylinder head to manifold gasket wouldn’t be a bad idea either
Old Jan 22, 2018 | 10:39 AM
jakgal04's Avatar
True, didn't even think of that one!
Old Jan 22, 2018 | 11:09 AM
RazorLab's Avatar
Originally Posted by jakgal04
Thank you!
Oil drain gasket
4x Manifold bolts
The lock washers are MR187848 and you need 2 per bolt as they stack.
Old Jan 22, 2018 | 11:59 AM
jakgal04's Avatar
8x crushes added
New revised list is below:
Oil drain gasket
4x Manifold bolts
8x Manifold lock washers
Engine > Manifold gasket
Old Jan 22, 2018 | 12:59 PM
e_kobz's Avatar
You’ll also need vulgar language and a 12 pack of your favorite beer
Old Jan 22, 2018 | 01:01 PM
e_kobz's Avatar
I did my turbo/manifold swap during an Arizona summer. Shocktop was oranges wasn’t a bad choice
Old Jan 22, 2018 | 01:38 PM
jakgal04's Avatar
Yeah I'm used to a nice challenge on this car. A few of my friends will be helping out. Getting some pizza delivered and having some nice cold ones should help ease the pain!
Old Apr 10, 2022 | 12:49 PM
Sharkbite2000's Avatar
Weird, I run 600 HP at the time red line time attack with the A/C on with no issues. Melting safety wire that's crazy!
Old Apr 30, 2023 | 12:17 PM
evoVI_PR's Avatar
MR187848 washers for Evo8 FP Green?
Sorry for bringing back an old thread, hopefully someone can chime in.
Will these washers MR187848 work on an Evo 8/9? I've only seen them listed for EvoX, but I don't see why they wouldn't work for my Evo8 with an FP green. I have the car apart to replace a turbo to manifold gasket, so perfect time for upgraded washers. Any thoughts?
Old May 7, 2023 | 11:07 PM
Lightsaber's Avatar
Double Belleville washers for Evo 8's manifold-to-turbo studs? I'm not certain, but I bet it should work just fine.
Speaking of the OP's Evo X hardware part numbers:
Let's say one prefers Mitsubishi OEM, then the OEM hardware's part numbers are as follows:
▪ Exhaust manifold gasket (x1): 1555A417
▪ Cylinder-head-to-manifold M10 flat washers (x10): MD132933
▪ Cylinder-head-to-manifold M10x1.25x42(?) studs (x10): MD146938
▪ Cylinder-head-to-manifold M10x1.25 flange nuts (x10): MR224500
▪ Manifold-to-turbo gasket (x1): 1515A184
▪ Manifold-to-turbo M10 H.D. super Belleville washers (x8): MR187848
▪ Manifold-to-turbo M10x1.25x34 bolts (x2): MN119783
▪ Manifold-to-turbo M10x1.25x?? studs (x2): MN119784
▪ Manifold-to-turbo M10x1.25 nuts (x2): MD132930
▪ Turbo-to-downpipe gasket (x1): 1555A289
▪ Turbo-to-downpipe M10 flat washers (x5): MD132933
▪ Turbo-to-downpipe M10x1.25x34 bolts (x4): MN119783
▪ Turbo-to-downpipe M10x1.25x?? stud (x1): MR224441
▪ Turbo-to-downpipe M10x1.25 nut (x1): MD132930
Let's say one prefers JDC titanium, then the names of JDC hardware kits are as follows:
▪ Exhaust manifold gasket (x1): 1555A417 (You still have to order OEM for this.)
▪ (Set of 10) M10x1.25x45mm studs, nuts, & washers: "JDC Titanium Exhaust Manifold Stud Kit (Evo X)" (p/n JDC-TI-EVOX-EMSK-6)
▪ Manifold-to-turbo gasket (x1): 1515A184 (Order OEM.)
▪ Manifold-to-turbo M10 H.D. super Belleville washers (x8): MR187848 (Order OEM.)
▪ (If OEM manifold) "JDC Titanium Turbo to Manifold Stud Kit (Evo 4-10/Universal)" /🔩/ (If MAP cast manifold) "JDC Titanium Turbo to Manifold Hardware Kit for MAP Cast Investment Manifolds (Evo X)" (p/n JDC-TI-MAP-CAST)
▪ Turbo-to-downpipe gasket (x1): 1555A289 (Order OEM.)
▪ (Set of 5) M10x1.25x45mm studs, nuts, and washers: "JDC Titanium O2 Housing Stud Kit (Evo 4-X)"
Let's say one prefers ARP stainless, then the ARP hardware's part numbers are as follows:
▪ Exhaust manifold gasket (x1): 1555A417 (Order OEM.)
▪ ARP M10x1.25x48mm broached stud kit 10pcs: 400-8026
▪ (If OEM manifold) ARP M10x1.25x48mm broached stud kit 10pcs: 400-8026 (4 here, 5 for turbo-to-downpipe) /🔩/ (If MAP cast manifold) ARP M10x1.25x48mm broached stud kit 8pcs: 400-8016 (3 here, 5 for turbo-to-downpipe)
▪ 🔩/ (If MAP cast manifold) Simply use the zinc-coated M10x1.25x80 long bolt that comes with the MAP cast manifold, or you can use JDC-TI-MAP-CAST or ARP 773-1010.
One way or another, using flat washers for cylinder-head-to-manifold and turbo-to-downpipe is fine. There are plenty of bolts and studs sealing these connections against heat expansion. But you must use double OEM Belleville washers for each of the 4 manifold-to-turbo holes. The 4 bolts/studs here have only so much strength. Without the double Belleville washers, they will stretch from heat expansion and cause an exhaust leak. Like AMS eloquently put:
Originally Posted by AMS
Replace the gasket with an OEM gasket, replace that missing stud with the stock bolt and coat the threads with anti-cease (not too heavy on it). Use the stock washers as well. Each bolt has two washers. These washers are very important in keeping the bolts from backing out. They washers have a conical shape to them and need to be installed face to face like a clam shell.
This should hold up just fine. [...]
Bolt part number: MN119783
Washer part number: MR187848 (two needed per bolt)
The correct way of installing double Belleville washers is mentioned in Evo X Service Manual 11B-22 and 15-21.
Rall1boy
Apr 21, 2013 07:32 AM
KJS
Jul 10, 2012 06:07 PM
BaumBizzle
May 26, 2012 12:26 PM
Evokid8
Jul 7, 2009 05:59 PM
HiRevnVIII
11
Oct 5, 2005 11:13 AM
