Boost not going above 10psi
Old Aug 27, 2020 | 06:20 AM
Ralliartevo1999's Avatar
Boost only hitting 10psi, have not done a compression test yet but need help diagnosing the problem. Car runs fine in the low revs, once I start giving it a bit more it hits 10psi and just sits there, so restricted.
Old Aug 27, 2020 | 08:52 AM
DontStopMe's Avatar
Have you done any recent work to it? Does it still have a catalytic converter?
Old Aug 27, 2020 | 09:47 AM
Biggiesacks's Avatar
Do a boost leak test.
Old Aug 27, 2020 | 02:42 PM
Got it tuned a while ago, was running fine. Happened out of no where. And yes still has cat
Old Aug 27, 2020 | 06:02 PM
kyoo's Avatar
something probably popped off/worked loose
Old Aug 27, 2020 | 06:11 PM
kaj's Avatar
kaj
Which WGA is on it? Is the boost solenoid still hooked up? Check for vacuum lines that have come loose or have a hold. Do a boost leak test. That's all I got for now
Old Aug 27, 2020 | 06:37 PM
stock WGA, solenoid hooked up. Checked all vacuum lines. I guess a boost leak test is my only option left atm
babaz7
Nov 3, 2012 03:18 AM
gpfury86
Jan 7, 2012 07:31 AM
ThatOneKid
Oct 5, 2011 04:31 PM
aka.ralliart15
34
Mar 15, 2011 10:53 AM
El Boricua
10
Mar 29, 2005 05:01 PM
