boost problem..need help plz!
hi i guess i didnt recive much help in the ecuflash section may be you guys in the engine section can help, so i did hard launches on my evo and some runs, after that i parked my car for like 2 weeks, so when i took it out and gave it a run in high boost setting but the thing is it was only going upto 1.2 bar which is exactly my low boost setting...i have a greddy pro-spec v2 boost controller..
my high boost setting is 1.8 bar
low boost setting 1.2 bar
what could be the problem.it was running fine the day i gave launches and some pulls, could something have come off? or is it some other problem?
i checked the boost controller the settings are the same i dialed in...
another question if i un plug the cars battery, will it change the boost controller settings?
i think i had the battery out for like 2 mins, that couldnt have changed the settings...cause ive done that before and i didnt change the boost settings
nspyr
26
Jun 20, 2017 02:08 AM
