Walbro 450 upgrade questions
Old Dec 6, 2021 | 10:21 AM
Metal's Avatar
Question Walbro 450 upgrade questions
Hey fellas,
I have the MAP E85 500+ hp fuel pump kit ready to install that comes with the Walbro 450. I have three questions:
1. I understand I need to drill out the return syphon housing if I hardwire the pump, is there a recommended size? I've read a huge range of sizes, should it be 5/64, 3/32, or something bigger?
2. Am I fine to pull out the tiny inline fuel filter if I'm adding an external inline fuel filter, to avoid future clogging?
3. If I use a HOBBS switch to trigger a relay for high power (at, say, 7 PSI) and retain the factory low/high power for operation below that, do I need to drill out the housing?
Thanks.
Old Jan 18, 2022 | 10:05 PM
harry wilson's Avatar
did you find it yet ?
Old Jan 19, 2022 | 07:26 AM
six40's Avatar
These are all questions I wouldn’t mind knowing too, I’ve read a lot of mixed info about it all and I don’t know what’s best
Old Jan 19, 2022 | 01:38 PM
schuhie's Avatar
I'm not an X guy but I can chime in with my knowledge from the 8/9 platform.
1) I have read lots of sizes too but the most common one I have seen is 5/64.
2) I would think you'd be fine to remove the filter. I know a few guys run a larger, higher micron one near the pump and then a smaller, lower micron one up near the injectors. I personally just have 1 large filter near the pump.
3) This is the setup I run on my 9. I have a double pumper (2x 255s) and the second pump is hardwired via a hobbs switch and a relay. If you retain the high/low setup of the stock pump, I don't believe you would need to drill the siphon.
Again, I'm not an X guy so take my answers with a grain of salt but I figured I could try and help a little.
Old Jan 20, 2022 | 12:02 PM
six40's Avatar
I believe a lot of the stuff you just said applies to the X as well. Thank you
Old Jan 20, 2022 | 03:10 PM
RazorLab's Avatar
I highly recommend saving some headache and getting the radium hanger with new venturi and getting a fuel pump controller.
wowzers
Apr 20, 2014 12:45 AM
04_k20a2
Feb 21, 2012 07:20 PM
Ultimate Racing
EvoX 'For Sale' External Engine / Power
18
Oct 25, 2011 04:38 PM
Speed Element
14
Mar 17, 2010 12:51 PM
