HELP WANTED code p0171, p0463, p0183
Old Jun 9, 2022 | 02:04 PM
IDK123's Avatar
Hello, has anyone out there self solved the code p0171. I've called the Mitsubishi parts department for help, they said there's more than likely a vacuum leak. So I used my leak detector solution spray in the engine bay while idling & got no luck finding a leak. I have recently installed a after market Cold Air Intake, and gotten a tune by the MAP access port. If you have solved this problem please let me know.
I've also just received the codes p0463 & p0183. I checked the ohms on the fuel sensor float, the lever & ohms matched how they're suppose to. Any suggestions on this would be great as well. I would rather fix these at home than spend lots of $$ at the mechanics, & regret owning an EVOX, LOL. -Thanks
2011 EvoX
IDK123
Discussion / Rumors
Aug 13, 2022 04:58 PM
IDK123
Evo X How Tos / Installations
Jun 9, 2022 02:06 PM
IDK123
Jun 9, 2022 01:57 PM
timschoeliertm
Lancer Troubleshooting
Jan 26, 2012 09:50 AM
P0411
Mar 2, 2006 08:25 PM
