cylinder 4 misfire, tried everything
Old Oct 20, 2022, 05:34 PM
Jaraxle's Avatar
So I've been chasing a cylinder 4 misfire / multi-cylinder misfire for over a year... Maybe even 2+ years....
1.) Replaced injectors with FIC 1650's (from FIC 1200's)
2.) Replaced Spark Plugs (NGK of course)
3.) Replaced all four coil on plugs (COP) with OEM units from dealer
It is coming up FASTER after an ECU code reset now. Sometimes as quick as TWO starts & runs of the car.
I'm open to any ideas on what the problem is, since I have replaced everything I would think that would be related.
The car is running fine, idle is sometimes a bit rough (on more % gasoline) but I am still smoothing out cranking tables, etc as the tank transitions from E80 to E17 to E10.
Old Oct 20, 2022, 06:56 PM
Biggiesacks's Avatar
I've dealt with these codes when tuning injectors / maf on my own car. So it's possible it could be an issue in the tune.
If you read out the codes it should tell you basic info from when it triggered the code, like RPM ,throttle position, coolant temp. You can use that info to compare against logs and the tune.
Old Oct 20, 2022, 07:43 PM
ViciousLSD's Avatar
I just turned off the check for my code. I've been racing the crap out of it but I dont feel any issue. My code normally comes out on the 2nd cold start, guessing the code was logged on the first drive. It's better so i dont have to ignore the light. The car is still great 2 years after
DontStopMe (Oct 21, 2022)
EDDY PRIME
Nov 17, 2020 12:43 PM
GunLake
Jan 9, 2020 08:03 AM
X2jesse1x
Aug 8, 2017 05:51 PM
fugiwara
18
Jul 3, 2011 03:23 PM
chad99evo
South Region
Dec 7, 2008 05:51 AM
Quick Reply: cylinder 4 misfire, tried everything
