Red fluid on transfer case
Old Oct 20, 2022 | 10:54 PM
Jestersplay's Avatar
So I bought a 2010 evo x MR just over a month ago. There is red fluid the seems to be coming fromnthe transfer case. The transmission is brand new rebuilt/built from Jack's trans. Every transmission wise is clean enough to eat on. Only has fluid on transfer case. What could be leaking? Pretty sure the transfer case doesn't have red fluid, but the ayc or acd whichever it's technically calls does. It seems to be only on the bottom hard to tell
Old Oct 21, 2022 | 07:47 AM
ViciousLSD's Avatar
yeah thats ATF for ACD. sometimes the o rings break or dont seat right when installed, especially by first timers. I put a bit of grey sealant on the o-rings now and for once I dont have leaks anywhere at all. check the banjo bolt for the fluid line also, maybe needs to be tightened
Old Oct 21, 2022 | 08:13 AM
I'll check the banjo, as for the o rings does that require removal of tcase? Id assume yes. And as longnas i keep the resivour full nothing should be harmed? I'm more familiar with the 8 platform.
Old Oct 21, 2022 | 08:45 AM
ViciousLSD's Avatar
yeah check the banjo and the bleeder first. I cant remember which internal seal is for the ATF but i think its possible its mixing with the gear oil and leaking thru the gear oil orings since its thinner than the gear oil.
On my IX I cant install the TC in one piece so I split it up. its a lot of work either way. ACD reservoir needs to be drained and refilled properly
Old Oct 21, 2022 | 08:56 AM
Ok thanks for the info. I'll check bleeder and banjo before even attempting the seals. Again im new to the X but not new to evos in general. I hope the ATF isn't mixing with/in the tcase lol
Old Oct 21, 2022 | 09:04 AM
ViciousLSD's Avatar
yeah keep everything super clean & dry so its easy to trace leaks and stuff. I even removed all the black undercoating . GL
hiboost2.0
Dec 27, 2012 07:38 PM
EVOlute GSR
Aug 27, 2012 11:08 AM
evonky
May 16, 2011 01:26 PM
5LEEPERISAH23I
Mar 16, 2010 06:26 AM
Rastmp
Nov 18, 2005 07:59 AM
