Sponsored by:
Sponsored by: CARiD
Boost gauge- What part of the firewall did you run the line through?
Old Mar 11, 2008 | 08:54 AM
TURBODAWG's Avatar
There is also a grommet where the washer fluid line runs from inside the car out thru the back side of the passenger side quarter panel (near the door hinges). If you follow the washer fluid line back into the car you will see it. I havent seen the one on the firewall yet. I will look tonight. If you have the glove box out, look towards the passenger 1/4 panel and you can see some access holes where the wires and hoses run out.
Brian
Old Mar 11, 2008 | 09:36 AM
Kerr's Avatar
Fomer Vendor
I also thought about running it that way, because of that gap in the fender, there is all that room for access. But I couldn't see a fast way to do it. Trying to fish a line through the inner fender well without dropping the fender liner seemed tedious. With enough time I'm sure that could be done.
Old Mar 11, 2008 | 10:54 AM
evo_Eks's Avatar
pictures as to where to run this line is greatly appreciated.
Old Mar 11, 2008 | 11:06 AM
Evo Tengoku's Avatar
Kerrformance F T W!
Old Mar 11, 2008 | 01:38 PM
Noize's Avatar
EvoM Administrator
TTT for pics
Old Mar 11, 2008 | 02:31 PM
Kerr's Avatar
Fomer Vendor
I will have them later tonight, I'm getting ready to head to the shop now to help finish up the car for tomorrow.
Old Mar 11, 2008 | 07:18 PM
Kerr's Avatar
Fomer Vendor
Sorry so late guys, but here are the pictures.
This is under the dash, you can see the extra "carpet".:
Here is under the hood, its hard to see, but if you follow that vacuum line back, that is the hole where the grommet is:
Hope this helps some of you out.
Old Mar 11, 2008 | 07:52 PM
PDXEvo's Avatar
Thanks for the information.
Old Mar 11, 2008 | 09:08 PM
nbpal4000's Avatar
yeah...im still debatin on where i should mount the boost gauge...
Old Mar 11, 2008 | 09:36 PM
evo_Eks's Avatar
thanks alot
Old Mar 12, 2008 | 12:49 PM
Noize's Avatar
EvoM Administrator
Its the Omori 46mm color changing gauge that I used in my IX. Its been lonely for nearly a year.
I used Kerr's spot to go through, thanks heaps for the pictures. That was about ten thousand times harder than doing a boost controller in an X, which took all of three minutes. This took closer to an hour doing right, using a hanger, etc. I got power fron the fuse box below. Cake on that part.
Old Mar 12, 2008 | 01:04 PM
BADEVO's Avatar
Originally Posted by Noize
I see that, but I don't want to drill my car. There was a grommet you could pop out in the CT9A cars. Is there not one in the X?
Quit begging and find a hole your damn self Seth! Ha ha ha ...whats up man?
We gotta chat man, I'm looking at getting an X in a few months as well. Debating on the MR with SST.
But anyway, when you find a good spot for the boost gauge line, let me know.
Old Mar 12, 2008 | 01:27 PM
Noize's Avatar
EvoM Administrator
Dan the man! What are you doing, sucker?!? We need to get together fo sho. Give me a ring sometime and PM me if you lost my number.
Old Mar 12, 2008 | 02:08 PM
Kerr's Avatar
Fomer Vendor
The gauge looks good Noize. Glad I could help some.
EvoRinga
Feb 20, 2011 06:17 AM
jhkim45
Dec 5, 2010 10:55 PM
freshpl
May 28, 2009 03:38 PM
ballinSTI
Nov 8, 2007 01:53 PM
