BlackTrack's weight reduction thread: Over 130lbs so far...
Can you buy a brand new 9?...Well someone should have kicked you in the nutts for not getting one
Sounds good. I think youll be just fine. If the car actually weighs 3600 lbs, or even if its a tad over 3500 lbs, that is definitely to your advantage. That will give you an opportunity to take more weight out of the car, and run it with a lower competition weight. Although, i would be sort of careful with that. If NASA later on realizes that they need to re-class its base weight, that will obviously hurt you. Although, thats not much of a big deal, because you can always add ballast. New cars are always re-classed in certain ways as the season progresses. If i were you, i would have put the car on scales before i did anything else.
What are your plans for Buttonwillow? Ill be free from the 26th/27th if you wanted to get together.
Ryan
AutoMotoSports
Sep 26, 2009 07:53 PM
BlackTrack
Aug 17, 2008 10:55 AM
