Sponsored by:
Sponsored by: CARiD
Boosting 26 PSI On Pump 91 Gas Is It Safe?
Old May 21, 2008 | 02:43 PM
ArchieBabes's Avatar
I'll turn the boost down tonight around 23-24 PSI.
Thanks Guys.
Old May 21, 2008 | 02:48 PM
housedj's Avatar
it is impossible to run that much boost on an EVO of any year with 91octane. evos in the southwest have shown signs of detonation running stock boost on 91. you sir are flirting with disaster.
please do not come to us whining in 3 months when u blow up ur motor...
Old May 21, 2008 | 02:50 PM
housedj's Avatar
the answer to ur thread topic is Hell To The No unless ur running a big turbo or a meth kit...
Old May 21, 2008 | 02:54 PM
Thegame's Avatar
If you are still on the stock tune, the ECU will protect the motor if you're overboosting. Something isn't right if you're boosting 26 psi and the ECU isn't pulling massive timing or throwing a CEL. Is the BOV line the best place to install a boost gauge on the X?
Old May 21, 2008 | 03:01 PM
It should be ok, because the BOV line connects to the intake manifold.
I don't know why the ECU isn't pulling timing or throwing a CEL???
And I never touched or flashed the ECU yet.
Before when I was stock when it boost past 23 PSI it feels like you are hitting a wall when the Fuel Cut initiates.
Jim in Tucson
11
Apr 26, 2011 05:09 PM
scorke
199
Jun 17, 2009 02:36 PM
razorlab
May 9, 2008 04:27 PM
Warrtalon
85
Nov 5, 2005 07:52 AM
