Sponsored by:
Sponsored by: CARiD
Is anyone familiar with the one-touch window switches on the X?
Old May 28, 2008 | 05:17 AM
JWA's Avatar
JWA
I was assuming that there are four separate switches under the switchpanel in the door (driver's), but at least one online pats catalog makes it look like the panel may be one entire unit. Does anyone know if the window switches are individually removable, and if they can be ordered separately?
Old May 28, 2008 | 06:02 AM
gunzo's Avatar
Originally Posted by stanrc
i don't want auto rolldown because what if its raining? but it would be nice to be able to roll them down some remotely, not automatically though.
No offense but you gotta be dumb to wind down your windows in the rain
You basically have to depress the unlock button twice and hold it down on the 2nd press to wind down the window .. so it's a conscious effort ..
Just read the japanese MMCS manual. The selection function is available under SETTINGs in the main menu under submenu ETACs .. no need to go to the secret hidden menu ..
So if you guys don't have that .. it could be deactivated on yours..
I was hoping you guys can access that menu .. I may buy the MMCS from you guys then ..
well .. back to the drawing board then ..
Old May 28, 2008 | 06:05 AM
GeorgiaBoy's Avatar
Is it possible to control the windows on the non navi evo x's with the keyless remote?
Old May 28, 2008 | 06:06 AM
stanrc's Avatar
oh well everyone was saying auto roll down on unlock. so i'm thinking when i unlock it the windows are automatically going to roll down haha. i'll see if i can get it working on mine later.
Old May 28, 2008 | 07:36 AM
gunzo's Avatar
That's a disabled program .. you can only wind up the window when you lock .. function is the same
Press LOCK twice and hold down the LOCK button on the 2nd push.. your doors will lock and any open windows will automatically closed too ..
Note that this is on Japan models .. hopefully it's also available in USDM models ..
Old May 28, 2008 | 07:38 AM
stanrc's Avatar
ok, i will try that out next time i go out to my car
Old May 28, 2008 | 08:34 AM
Jonasan50's Avatar
There are alarms out there that have the rolldown option. As well as remote start.. Check with a local car stereo/alarm installation place.. They can tell you have to do it, and what other servos you might need..
Old May 28, 2008 | 10:16 AM
mmartahus's Avatar
i got to the menu, but there is nothing about changing auto roll up/down functions.... id really like to be able to make the windows auto roll up when i lock the car if possible with the FAST key, is this possible?
Old May 28, 2008 | 03:29 PM
gizmotoy's Avatar
I tried this one mine and it didn't work. I have the FAST key and no Navi, so maybe there's a way to enable it somehow but it doesn't come enabled from the factory.
Old May 28, 2008 | 03:56 PM
stanrc's Avatar
i tried it on mine earlier and no luck. i have the nav unit and went to the service menu list but there wasn't anything in there to change it either.
Old May 28, 2008 | 04:31 PM
gunzo's Avatar
Just read the white paper on ETACs ..
Universal ECU and programming .. but certain functionalities are disabled based on VIN and locations
You guys may not have these functions ..
Pretty sure you get the autowindup .. then again .. who knows what mitsubishi is thinking ..
Read carefully !!!
press lock twice .. hold down the lock button on the 2nd push!
You can try this also .. it's either 3 press of the LOCK button .. 3 press of the unlock button (fold and unfold wing mirror)
Old May 28, 2008 | 05:34 PM
gizmotoy's Avatar
Read carefully !!!
It's not exactly rocket science. It just doesn't work, and it's apparently not in the Navi menus either, so it's not looking good for the USDM. I went through the user manual too, and no mention of it there either.
Old May 28, 2008 | 05:41 PM
max2evoix's Avatar
just get 2 window modules 1 for the front and 1 for the back..then youll have one touch for all 4 windows.!! you can even get one for the sun roof if you want totally pimp
dei makes some really good ones
Old May 28, 2008 | 06:52 PM
gunzo's Avatar
Oops ..
Guess it's disabled then .. or not available for USDM cars ..
The functions are written clearly in the Japanese user's manual ..
Old May 28, 2008 | 10:35 PM
mmartahus's Avatar
