Sponsored by:
Sponsored by: CARiD
Blown off?!
Old Jun 11, 2008 | 06:47 AM
MrBonus's Avatar
With the pipe being bolted down to the frame, how exactly are they blowing off?
When I first installed my UICP, I didn't tighten it and had an audible boost leak but couldn't get the damn thing to blow off.
Old Jun 12, 2008 | 09:42 AM
love9sick's Avatar
The bolts on the frame where on still tight...the pipe literally moved the rubber hose right off to the side.
Old Jun 12, 2008 | 02:25 PM
Thegame's Avatar
This is why my first mod was a set of tbolt clamps!
Old Jun 14, 2008 | 12:03 PM
AkumaMax's Avatar
yea those are nice. I will take full blame for my noobness! When I put the cupler down on the IC I went too far down so it was taking up 75% of the cupler and the IC pipe was only getting 25%. I fixed it to where they both had 50% of the cupler. I will also say that the god damn pipe will never come off now. I thightend that thing real good now!
Old Jun 14, 2008 | 01:12 PM
STi2EvoX's Avatar
How could the coupler that connects the charge pipe to the intercooler blow off? That pipe is bolted to the frame of the car and cant move. The engine moves back toward the firewall when it is under load which would pull on the long black hose between the pipe that goes to the intercooler and the small aluminum piece that necks down to go to the turbo. There should't be any tension on the piece that you say blew off. I'm confused.
Old Jun 14, 2008 | 06:10 PM
Ferraritech's Avatar
tighten those hose clamps
Old Jun 15, 2008 | 10:15 AM
Jonasan50's Avatar
Wow.. I'll be sure to have the techs tighten all the hoses before I roll out in my new MR... Seems like this is a common thing with the X's...
Old Jun 16, 2008 | 12:46 PM
junction's Avatar
My Upper IC pipe just blew off on the highway in 5th gear. The lower rubber holding it came off. Check engine light came on and I drove about 1 mile more home. Any damage...help please. If I just put it back on will it be fine?
If you don't have the clamps on precise and torqued down propper this will happen. Happened to my VIII numerous times so I would just carry around extra clamps and set of screw drivers just in case. Engine should be fine I would say.
Old Jun 16, 2008 | 07:17 PM
love9sick's Avatar
Not really with the stock upper IC pipe...usually a weak clamp installation. The X in general doesn't have this problem.
evoforlife
17
Jul 10, 2012 10:25 AM
feimax
Apr 15, 2010 01:18 AM
David Fogleman
Dec 29, 2009 08:26 AM
subrwho
Aug 24, 2007 12:02 AM
RevMoto
May 16, 2007 04:25 PM
