Sponsored by:
Sponsored by: CARiD
Asc off
Old Dec 28, 2009 | 04:55 AM
David Fogleman's Avatar
Asc off
My Asc off light just came on. what are the reasons for this because the manual just says to go straight to mitsubishi. Thing is i dont really have a mitsu nearby. Can you give me any advice on this.. thank you.
Old Dec 28, 2009 | 05:06 AM
Clark_Kent's Avatar
What were you doing? A little more information would be helpful.
Old Dec 28, 2009 | 05:18 AM
I wasnt doing anything different. i had just put my intake and upper intercooler piping about 2 weeks prior. but what i noticed was when i am at a complete stop, i take my foot of the brake and it doesnt go all untell i press the gas. you know it should go in idle speed, but it doesn't. its a MR so its an automatic.
Old Dec 28, 2009 | 05:50 AM
therocket's Avatar
If I'm not wrong, this can happen when airflow or boost exceed limits, for example after a performance tune or if the MAF sensor does not read properly the airflow. On MR, this can also lead to bad gearshifting and in general bad behaviour of the A/T.
Have you already tried to remove your intake (by the way, which intake is it?) and replace the stoke one? Intakes usually lead to incorrect MAF readings.
Old Dec 28, 2009 | 05:52 AM
Yousef's Avatar
funny!!!
look here
https://www.evolutionm.net/forums/ev...-required.html
Old Dec 28, 2009 | 11:53 AM
daniel_f_us's Avatar
If I were you I'd replace the factory components and take it straight to Mitsubishi...use that warranty!!!
Old Dec 28, 2009 | 05:09 PM
Evo Andy's Avatar
The only time I ever see that screen is when I hold the "ASC" button in for 5 sec or more, than I go out and play.
Just pressing it once to "off" does not fully shut it off,even though you may think it does. . try it.
Old Dec 28, 2009 | 09:01 PM
ik78's Avatar
Does it go on every time you stomp on your gas pedal? I had a BOV and that what cause my that light to come on. I brought my car into SCM and they couldn't find any problem, but they told me to switch back the stock bov and see what happen. They said it might be the air pressure. Ever since then the light never turn on.
Old Dec 29, 2009 | 07:31 AM
ugakirk's Avatar
Yea my car does that now if I try to use the 2-step. I never actually launch it but I just rev it up and It does that to me. I have the Cobb AP and I just clear the codes and the light never comes back on. It prolly is just the ECU saw too much boost or air. Maybe disconnect the battery and press the brake pedal a couple times and wait. See if it clears it.
Old Dec 29, 2009 | 08:26 AM
phillyexox's Avatar
have you tried resetting the ecu by removing the battery terminal?
flyguycfi
May 30, 2014 03:35 AM
Mark Hubley
Lancer How Tos / Installations
18
Mar 30, 2011 05:06 PM
bacquerel
Nov 4, 2010 08:33 AM
Dboey
Dec 27, 2009 06:10 AM
LVSBB6
Mitsubishi TC-SST Discussion
45
Aug 30, 2009 12:29 PM
