Sponsored by:
Sponsored by: CARiD
Premium fuel?
Old Jul 12, 2008 | 05:34 PM
92gsxbaltimore's Avatar
you should run 91 and up
Old Jul 12, 2008 | 05:36 PM
evo L's Avatar
drive further and get the right fuel, or if you have a programable EMS have it tuned for the fuel in your area. you can technically have your car tuned to run on anything(gasoline), sure you might take a power hit but the safety will remain.
Old Jul 12, 2008 | 10:36 PM
ODUB's Avatar
it must suck to have to deal with 91. pretty much every station i've ever seen is 93. every once in a while you'll stumble across a 92, but that's rare.
Old Jul 12, 2008 | 10:47 PM
EvoRecordSetter's Avatar
Originally Posted by Jbtownsoccer22
i would never use unleaded on the evo
Originally Posted by JoeyM3
so you run leaded race gas everyday?
i think hes talking about base grade gas. whatever the lowest is.
Old Jul 30, 2008 | 05:32 PM
edgley's Avatar
In the UK it seems most sell octane 97, and the sticker in the petrol cap says 98.
Will this cause a problem for me please?
Old Jul 30, 2008 | 06:09 PM
Dyno4mance's Avatar
Glad my HFS-5 is sitting on the bench waiting to be installed in my X.... 89 + 1200cc/min 100% VP M1..........
I don't think it will come to that but it's nice to have the option.
Old Jul 30, 2008 | 06:14 PM
nothere's Avatar
premium gas is regular gas with cooling additives to quell detonation. Those additives hurt btu(s).
If you could keep out of boost you would get more power out of regular than premium.
not saying you should, who can keep out of boost. Some one with water/ meth might get away with it.
SME's Avatar
SME
Wont happen
Old Jul 30, 2008 | 06:24 PM
Chayevo's Avatar
not gonna happen
Old Jul 30, 2008 | 06:39 PM
Impulsoren's Avatar
Add a couple gallons of 100 octane to each tank of 90.
In fact, I add a couple gallons of 100 octane to a tank of 92 when traveling long distances on the highway to extend the refill interval. It is not necessarily cost-effective (it ends up costing a tiny bit more per mile than straight 92) but not having to stop for gas until 350 miles is good.
Old Jul 30, 2008 | 10:11 PM
Jonasan50's Avatar
Any boosted car needs premium.. If u do, don't be boostin..
Old Jul 31, 2008 | 08:21 AM
gvillevo's Avatar
Isn't the octane rating system different overseas? Like their 98 ron is equivalent to our 93? more info...http://www.petrolprices.com/about-fuel.html
Old Jul 31, 2008 | 08:36 AM
fastrob691's Avatar
NM has 90 octane, and 86 regular, 88 mid grade. Try that
Old Jul 31, 2008 | 09:30 AM
Bandit312's Avatar
1: The sales of Premium are going down with the people that buy it for cars that don't 'require' it... thinking that it's somehow better or cleaner for their car... (which of course we all know is not the case) cars with high compression or boost usually will require 91 (which I believe someone already pointed out)
2: it's pretty much a misnomer to think the higher the octane the better, my truck runs on 116 but guess what, if I don't reprogram the ECU it will do nothing... I may as well be running 91 in it...
3: water/meth injection does a couple of things... a: it helps you run cooler b: it allows you to advance your timing... obviously this means more power...
Lastly, I'm no tuner, nor am I an expert on anything to do with cars, but I'm pretty certain that what i've stated is correct.
and that's my 2 cents... oh by the way.... I can't see unocal/shell/chevron doing this anyway... (as most people already agreed)... especially in socal... too many vehicles here require it...
Old Jul 31, 2008 | 02:00 PM
Thegame's Avatar
I agree with most things you said. However, (and I could be wrong) stations like Shell claim their V-Power 93 has special additives and detergents to help keep valves, injectors, combustion chamber, etc. clean. Now I don't doubt the fact that stations like Shell, Sunoco, and BP (Amoco) do have a higher concentration of these cleansing agents and additives than stations like Sheetz and Get-go. I don't think, however, that Regular 87 has these same additives. So, many guys with cars not requiring premium fill up with 91 or 93 on occation. They do so to benefit from the purer, more refined, and better cleansing fuel more so than to benefit from higher performance. I've always heard stories about failing emmisions barely and shops suggesting to run on a tank of 93 instead of 87 for a week supposedly because it may help. Now a lot of this could be myths, but I do beleive that brand name premium fuel is the best way to go for anyone no matter what you drive. Sure it may be a waste to run 93 in a Civic, but chances of carbon deposits and such will be lower on a car run strictly on 93 than on a car run on stricly 87.
