Sponsored by:
Sponsored by: CARiD
Evo X GSR replaced through lemon law
Old Aug 25, 2008 | 01:32 PM
  #46
bmguser's Avatar
Exclamation
Honestly, Revolution86's explanation makes the most sense from all the posts i read... other than that, then the TSB for the idle issue would explain the other symptom.... end thread??
Originally Posted by REVOlution86
i can explain it cause it HAPPEN TO ME TOO!!!! it happened after a few races down in miami on okee well i noticed the light came on after i had a few freinds ask me to rev to see what it sounds like but i agree with you anyone who has an evo x try reving it up to 5k a couple times after you run the car and youll see it happen i took it to the dealer the code was never there so i think it has to do with the ecu thinking its launching and that the s-awd is malfunctioning because its not griping.....its like an ice effect say your driving on ice and your tires lock up .... its basically the same thing only your ecu thinks theres damage to your car somewhere making it not able to rotate your tire when you florit
Old Aug 25, 2008 | 03:57 PM
  #47
machron1's Avatar
Wow is evom full of X protectionist haters now? some of you sound like the "it's supposed to do that and it's your fault" warranty-denying mitsu district managers. this car is controlled by a lot of mechatronics (hardware + software). with the software side comes bugs, especially at the integration level between 2 or more systems. the condition which produced/produces this error is obviously a boundary condition not tested during development. it is not normally possible to even get a 10% use-case coverage during testing, so there is no such thing as a bug-free non-trivial system. the OP simply discovered a bug, which appears to be benign, but could possibly be a fatal flaw under different circumstances (such as heel-toe work when free-revving around that same rpm range is very common to match the speed of the engine to the transmission). if more people can reproduce this error and then report it through the dealer network, it will give the engineers more data points from which to produce a bug fix which can then be applied to everyone's car via a re-flash. the OP is doing a service to the evo community, and said many times he is happy with his purchase, but is just passing along this info to broaden the knowledge base. anyone discouraging such posts is doing a disservice to the community, ESPECIALLY when done in a childish and mocking manner.
Old Aug 25, 2008 | 04:29 PM
  #48
machron1's Avatar
So, what is the code thrown when this problem shows up? i wonder if it's the "partial throttle overboost" code. If that's the case, this problem can probably be solved by raising that limit on the ECU.
Old Aug 25, 2008 | 07:25 PM
  #49
chriswolf81's Avatar
I will know by tomorrow afternoon and will post it then.
Old Aug 25, 2008 | 08:10 PM
  #50
hova00's Avatar
chriswolf81- You had a problem with the car and it is your right to have it fixed, get a new car, or have them just buy you out. I commend you on taking the appropriate actions. I apologize for the new members with 2008 join dates talking out of there **** on so many threads. Most seasoned members would know that free reving your car a few times will not damage anything. Its not like your pinned at redline.
Old Aug 25, 2008 | 08:14 PM
  #51
love9sick's Avatar
Now I am scared to rev my car in stationary lol. Anyways, I revved it before but not a few times as high as it goes.
Old Aug 25, 2008 | 08:45 PM
  #52
xtremeboost's Avatar
Let me know that code I may have had this issues already .
Frank
Old Aug 26, 2008 | 08:08 AM
  #53
ExcessLancer's Avatar
Mechanics rev cars high all the time when fixing them...
Old Aug 26, 2008 | 08:54 AM
  #54
Asta4125's Avatar
Holy bs thread....damm. +1000000 on what you said. The guys car obvously has a problem. The retards saying that he is doing something wrong by reving his motor a little to hear the exhaust is one of the most rediculus things I have ever heard. Reving his motor to 4.5k a couple of times wont do a thing. Now if he was sitting there doing it over and over and over again i could understand..but not in his case. I am shocked at the responses that different people gave this guy. There is something wrong..no car should throw a traction light while free reving a couple of times..and to the iddiots who say..."well if it happend the 1st time...dont do it again" Is hands down the dumbest statement I have ever heard of. People if you dont know what your talking about....please dont post. It makes it harder for the people who are trying to learn something as well as the op. To the op...good luck man, dont listen to these nuckle heads on here telling you, that your doing something wrong...your not..there is a bug in your ecu somewhere, and by no means is it your fault.
Old Aug 26, 2008 | 09:06 AM
  #55
CatalystGod's Avatar
+1
Old Aug 26, 2008 | 09:40 AM
  #56
ZEUS EVOX's Avatar
Originally Posted by CatalystGod
+1
+999999999999
Old Aug 26, 2008 | 10:05 AM
  #57
jwoods986's Avatar
+10000000000, reving what is supposed to be a "high performance" car to 4.5K shouldn't be a problem.
The X is on my shopping list, but if it can't handle a little reving in neutral - forget it! I'll go with good old natural aspiration, like a G35 or G8.
Old Aug 26, 2008 | 10:42 AM
  #58
iy's Avatar
iy
The return to idle slowly is an emissions thing. Many new cars do this.
The blinking light...maybe you turned on launch control or something? Or turned off traction control? That's what it sounds like...
Old Aug 26, 2008 | 01:51 PM
  #59
My mechanic called in sick! Appointment tomorrow afternoon.
I will post the code then.
Thanks for the constructive replies. I am only getting the ECU cleared, so the code is gone and do the reflash. They won't try to repair, since they have given up.
I think it is a normal occurance, which most likely would occur in all stock evo's under the same condition. I'm sure a tune could fix this problem permanently.
For my part, I'm never revving it like that again. I don't drag-launch the car, so I guess there is no reason to rev higher than 2.5-3K. (for quick starts.)
Old Aug 26, 2008 | 04:55 PM
  #60
TruboPower's Avatar
Some of you guys are retarded. It doesn't friggin matter that he was revving the engine up, he could bounce the damn thing off the limiter and it wouldn't matter. The cars already broken in by 250 miles anyways. You all sound dumb criticizing something thats nearly irrelevant.
The issue lies in that the car shouldn't being throwing lights from a simple rev..
