Sponsored by:
Sponsored by: CARiD
Engine idle clicking and clapping noise
Old Dec 12, 2008 | 09:17 PM
sl0ev0's Avatar
im also hearing this ticking. its more then likely normal
Old Dec 12, 2008 | 11:11 PM
Sabot's Avatar
I have the clicking too 310 miles on my X but with my experience with Imports is most likely normal.
Old Dec 13, 2008 | 01:14 AM
FQStormTrooper's Avatar
Is it a constant noise, or a clack every couple of seconds?
I've got a feeling it's the aircon compressor snapping on and off that you're hearing.
Old Dec 13, 2008 | 07:45 AM
rtremaine's Avatar
The sounds you hearing when you turn the key on and first start the car are more than likely the abs pump/system firing up and going thru its diagnostic routine. The ticking and clacking you hear when idling is probably normal, it is simply the injectors and coils firing and possibly the mivec solenoids cycling. The ticking noise you hear after it's shut off is usually just exhaust system and other components creaking and clicking as they cool and heat soak after the engine is shut down. My car makes all the same noises.
Old Dec 13, 2008 | 08:07 AM
toshibakoludo's Avatar
Wink
^ Bingo, on the abs pump and the rest too. I like the the ticking sound and the way the car idles it just sounds like a engine that can make 291 hp from 2.0 liters. Sweet sounds Evolution FTW
Old Dec 15, 2008 | 05:43 PM
stefnepton's Avatar
Has I wrote, it was during idle... when hot. The last day, no clicking. Maybe it was not cold enough.... to be continued (I'll verify with other evo x)
PATRICK B.
Dec 5, 2010 06:45 AM
Rcebowl
Sep 13, 2005 05:47 PM
DARKMETHOD
23
Jul 8, 2004 04:44 PM
Billy
Nov 8, 2001 04:13 PM
